Sponsored by: CARiD
How to manually close power windows?
Old Aug 14, 2006 | 05:29 PM
NewCar's Avatar
Angry How to manually close power windows?
Well the driver side window in my '99 TA will not go up. I replaced the switch, but that didn't solve it. I don't think it's the motor because it wasn't acting like it was starting to go. Went up & down fine then later last night when I got home & went to put it up it went up a little & just stopped & won't move now.
Is there a way to get the window up?
Old Aug 14, 2006 | 05:46 PM
joshp14's Avatar
Take the door panel off, un bolt it from the arms and tape it up....thats the only way unless you get the motor working.
Old Aug 14, 2006 | 05:52 PM
austin21's Avatar
actually if you sit and wait for a little bit then try it again with the key turn on the in will go up a little more and just keep doing that untill you get it up then i highly suggest you go get another window motor and replace your old one
Old Aug 14, 2006 | 07:33 PM
NewCar's Avatar
No, it will not move at all. It's been 2 days now.
Like I said, it does not seem like it is the window motor.
Old Aug 14, 2006 | 07:45 PM
Phoenix 5.7's Avatar
might sound obvious, but have u checked all the fuses?
Old Aug 14, 2006 | 07:48 PM
austin21's Avatar
y wouldnt it be the motor, im trying to tell you from experiance me and kyle (99camarosupersport) just put a new one in his drive side because it did the same thing now it works fine
Old Aug 15, 2006 | 07:42 AM
2001chevroletz28's Avatar
it is the motor I bet you...
Old Aug 15, 2006 | 09:09 AM
ChocoTaco369's Avatar
Tech Resident
they're like $40 at autozone. even if it's not the window motor, now you have a motor that's actually superior in design to the stocker. the $40 autozone ones i've heard work better and are faster than the GM ones
 Michael S. Palmer
Old Aug 15, 2006 | 11:41 AM
jmm98LS1's Avatar
They're $55 at autozone and they do perform much better/faster than the stockers, plus have a lifetime warranty so you'll never have to buy another one....until the other side dies. But after that you'll never have to buy one again.
