Sponsored by: CARiD
HEadlight motor... is it to late
Old Aug 30, 2006 | 10:17 PM
00transamnh's Avatar
Default HEadlight motor... is it to late
Hey my headlight motor stopped working (driverside)... ie it doesnt pop up but the light works
does this mean i cant do the metal gear replacement (i searched but im a lil confuesed if its applicable)
do i have to buy a whole new motor now?
this happened a year ago too (the dealer replaced it right before i bought the car)
Old Aug 31, 2006 | 08:49 PM
Tainted's Avatar
you need the motor itself. the gear is only a fix for cars that have the stock gear that grinds
Old Aug 31, 2006 | 08:51 PM
LILWS6's Avatar
if you still hear the motor turning when you flip on the lights then you should be able to put a gear on it was it grinding before it completly died if not then i would assume you need a motor
Old Aug 31, 2006 | 09:36 PM
DAMN!...yeah i wasnt hearing any grinding before and dont hear it now
Old Sep 10, 2006 | 04:32 PM
KameleonTransAm's Avatar
Hey I'm sorry to bring back this thread but I'm now having the same problem i flip the **** on my 00 T/A and the passenger headlight comes up fine but the driver side just sits there. I looked and saw all of my lights are on (including the headlight itself) so I dont think its electrical and there is absolutely NO noise so I know its not the basic gear issue. The headlight just sits there not making any noise and doesnt move any help appreciated.
Thanks in advance for any help
Old Sep 10, 2006 | 04:45 PM
Tainted's Avatar
^^ motor
Old Sep 10, 2006 | 04:49 PM
yeah dude, its your motor... if you want to get by for now (i didnt know about this) there is a **** on the top of your headlight motor that you can turn with your fingers in order to put the light up manually
Old Sep 10, 2006 | 04:50 PM
Thanks for the quick reply do you know roughly how much a motor costs?
100 bucks on ebay
Old Sep 10, 2006 | 05:03 PM
Tainted's Avatar
bout 100 bucks
Old Sep 10, 2006 | 08:48 PM
taintedmeat's Avatar
Did you check the fuse for the motor?
Old Sep 11, 2006 | 12:04 AM
No I havent got to check the fuse yet and to be honest I'm not even sure how (I know I probably sound like a moron) but I definitely will try and check everything before I dish out $100
Oh and I didnt even see the post referring to the manual flip up switch that is good to know thanks. And here I thought I'd have to drive around winking at everyone
Old Sep 11, 2006 | 08:17 AM
The fuse is in the main fuse box in the engine bay. Seems to me like it would make at least some noise if it was getting power, unless of course the electric motor itself is just seized.
Old Sep 12, 2006 | 08:26 PM
5.7 Reasons's Avatar
Before you purchase that motor, you might want to make sure that the headlight arm, that extends from the motor to the headlight door is making contact with the stopping points on the car. If this arm isn't reaching the stopping points your headlight motor might be "confused" and will just sit there doing nothing. To solve this you can add a rubber hose or something along those terms to allow the arm and stopping points to make contact.
Old Sep 14, 2006 | 06:52 PM
BAD LUK's Avatar
I agree.
I had the same problem with my drivers side motor. It kept getting worse over the summer.
It was to where I would turn the switch, the passenger side came up, but he driver side wouldn't. I had found that by turning the switch off, going and jiggle the driver side cover and it would come up after that.
After a while, this didn't even work. I ended up looking at the mechanism and seeing the adjustable stop near the top of the cover was adjusted to far in (no contact when closed) and that the plastic covered metal tab for the motor arm was bent back a little. This was probably allowing the motor to over rotate or something when it closed, confusing it somehow???
Anyway, I was able to get that side open and bend the tab back fowards. Works every time now!!
