help me fix my clunk
did you change your torque arm brackets?....the panhard bars bushing tend to go out, along with the lca's bushings....start with those
Im using a Spohn on my 87 TA...and I ended up beating the floor in with a hammer before I even got done with the rear suspension. Mine hits only on the hard bumps now...but has been getting better. Most of the time they clearance themselves.
Just something else to check out!
justin
What you are describing sounds like it could be something ehxaust related, that only does it when driving over certain surfaces. Things under a car do funny things when the weight of the car is moving around. Sometimes you can crawl under the car and yank on things with all your might and not hear or see anything. But when the 3500lb car starts moving around on it..you get the noises.
Just check around real good make sure that torque arm isnt hitting anything, and that the two long bolts are good and tight. They have a habit of coming loose.
justin
