Sponsored by: CARiD
Changed original Fuel Filter at 105K!!
Old Nov 16, 2006 | 11:27 PM
  #41
taintedmeat's Avatar
Originally Posted by BayAreaSS
My autozone doesnt carry GC
Is it the only one near you?
Old Nov 17, 2006 | 02:50 AM
  #42
BayAreaSS's Avatar
I've been to two different autozones and they dont have it
Old Nov 17, 2006 | 11:12 AM
  #43
mattraypharbor's Avatar
i changed mine at 60 something and i couldnt blow through it and i washed it out to see what would come out and allot crap came out the inlet side ...
Old Nov 17, 2006 | 03:49 PM
  #44
2001somws.6's Avatar
Well i just got done changing the filter out just before 40k and it looks like the stock one. Now i know there is a new one on there. I Jacked the car up and got under there. I even gave myself a tire rotation while i was doing this. The old one looks pretty dirty in there.
Old Nov 17, 2006 | 05:59 PM
  #45
Flawless02SS's Avatar
Originally Posted by YoMommasTA
lol he didn't post werid,he posted werd
LOL, I just noticed that when I scrolled back up, LOL! I guess I just looked at it too fast and really didnt read it, LOL!!
Old Nov 17, 2006 | 09:04 PM
  #46
BayAreaSS's Avatar
Thats what i've been meaning to do (rotate tires!!!)
Old Nov 17, 2006 | 10:57 PM
  #47
misfits's Avatar
my stock fuel filter was on my car for 55k and 7+yrs lol
  #48
ChocoTaco369's Avatar
Tech Resident
WS6Store sells it now. $39.99 for 6 bottles.
http://www.ws6project.com/user_stor/...e1d3af7fae72b2
Old Nov 17, 2006 | 11:18 PM
  #49
BayAreaSS's Avatar
Thanks for the link
Old Nov 17, 2006 | 11:25 PM
  #50
Tech Resident
Thanks for the link
np
Old Nov 18, 2006 | 06:07 AM
  #51
Kalgorn's Avatar
Well after reading this post I've decided I'm going to do this real soon. I'm checking out the www.installuniversity.com write-up and they disconnect the battery and pull the fuel pump fuse. Is this really necessary? I don't see how the fuel pump could start up if the keys are out of the ignition completely.
Or should I just do it for safety's sake? I never worried about it on any of my other cars (disconnecting the battery and fuse, that is).
Old Nov 18, 2006 | 07:38 AM
  #52
BayAreaSS's Avatar
I didnt disconnect the batttery or pull the fuse. That just seemed a little excessive.
Old Nov 18, 2006 | 09:57 AM
  #53
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Nope, not necessary at all. It's just silly, IMO. I wouldn't even consider wasting my time to do that. A fuel filter swap should go faster than an oil change. Easy stuff. No need to complicate it with extra steps like that.
Old Nov 18, 2006 | 07:33 PM
  #54
BayAreaSS's Avatar
Old Nov 19, 2006 | 08:23 PM
  #55
SpdFrk1990's Avatar
Ill be changing mine next weekend probably and think ill go with a Napa gold or a ac delco. 26k miles here.
Old Nov 19, 2006 | 10:15 PM
  #56
Tech Resident
i got a Napa gold filter. they make one of the best oil filters, why not a fuel filter, too? it was only like $13. it should only take 30 minutes to do. it may be kinda stuck like mine was. it's harder to get the new filter on than to get the old filter off, that's for sure. it took some fancy finger work to get the new one on. got a nice scrape on my arm on the concrete. i felt like a real man, what with the blood and all
just be prepared to get your arm covered in gas and smell like gasoline for 2 days. that's how you know you did it right. real men smell like gasoline anyway. if you come out of this smelling like downy, you should have probably spent the $13 on hand lotion, diet soda and fat free pringles.
btw, you SHOULD disconnect your negative battery cable. the fuse is NOT NECESSARY. you also definitely need to uncap your gas tank, and purging the shrader valve helps, too. it takes literally 3 seconds and leaves a spot of gas on a towel the size of a quarter.
Old Nov 19, 2006 | 10:54 PM
  #57
SpdFrk1990's Avatar
Hey thanks for the advice I done one on my thirdgen b4 they r basically the same and in the same location its pretty easy .
Old Nov 20, 2006 | 05:40 AM
  #58
RPM WS6's Avatar
No need to pull the battery cable. No need to pull the fuse. No need to purge the fuel rail unless the motor was recently running.
Real men leave the battery connected for things like this.
Old Nov 20, 2006 | 07:00 AM
  #59
CJDZ24_Z28's Avatar
Well the Philly F.B.I Sucks!
I changed the one on my B4C Camaro last week and it was the original. I will be doing the one on my SS in like 4 hrs. BTW Pep Boys sells the Purolator for $8.99
Old Nov 20, 2006 | 09:29 AM
  #60
blackbirdls1's Avatar
Changed the filter on Monday. Very little fuel came out, all I did was take off the gas cap on a low tank of fuel.
