WOW i just seafoamed my car.
Old 11-21-2006, 09:50 AM
TX_SS's Avatar
Default WOW i just seafoamed my car.
after thinking, i decided to do a seafoam experiment. here is the list of run down what i did.
step1
when engine was nice and cold, i added half can of seafoam into the engine.
step2
drove to near gas station and put whole can of seafoam into the gas tank and filled it with 93 ocatne fuel
step3
when back to my house and added that first half can of seafoam into brake booster hose.
step4
after 20mins i started and let it sit there for another 10min and drove. like a mad man.
there was SMOKE EVERYWHERE.. (WHITE) i made a thick *** cloud above my neighborhood and God was pissed cuz mine looked hella lot better than his.
result, my car seems to be lil bit better throttle response and thatz about it.
after 100miles ill do the oil change and see what happens.
Old 11-21-2006, 10:54 AM
bjamick's Avatar
let us know if it help your gas mileage any
Old 11-21-2006, 01:51 PM
TORCHD 02 TA's Avatar
man i can not wait to do this to my 192K mile toyota
Old 11-21-2006, 02:10 PM
SHINER's Avatar
i know some stuff that blows seafoam out of the water and cleans up what seafoam left behind, gauranteed.
Made by AMSoil
Power foam- half the can through the throttle body with the car off. Let sit for 3-5mins.
Turn the car on let idle for 5 min(do not rev)
While car is running take brake booster line spray the other half while car is running dont touch the gas..wait till its all been sucked up...wait three mins...and then go get on it...man pure black smoke after my seafoam treatment that was 2 months ago..
Then pour in AMSoil P.I. in ur fuel tank then fill up on premium..helps ALOT with gas mileage on my cammed car.
Trust me its worth trying.
Old 11-21-2006, 08:21 PM
SpdFrk1990's Avatar
You sure the amsoil stuff is ok to pour down the booster hose the website says this.
Spray on area to be treated. Rinse from exterior engine surfaces. No need to rinse from carburetors or other interior engine surfaces. Avoid contact with hoses. To prevent the dissolving of paint, do not overspray. AMSOIL Power Foam is not recommended for use in diesel engines.
Old 11-21-2006, 08:31 PM
i wold stick to the sea foam.. it is known, people trust and it works. but that is me
Old 11-21-2006, 08:52 PM
SHINER's Avatar
yes im sure. Its just a cleanser, just like seafoam....but way better. I wish someone would try this, im all alone here
Old 11-21-2006, 08:54 PM
SpdFrk1990's Avatar
I might try it in the spring I just ordered a bunch of stuff from amsoil too. I just worry about the part that says avoid contact with hoses.
Old 11-21-2006, 08:58 PM
yup you are alone on this one here
Old 11-21-2006, 09:03 PM
SpdFrk1990's Avatar
I could always pull the pvc hose and spray it right into the intake tho.
Old 11-21-2006, 09:43 PM
SHINER's Avatar
suit yourself, i was once like you addicted to seafoam, then tried this and will never consider it again. Dont be so close minded.
Any solvent is going to dry up rubber material, seafoam is a solvent.
Old 11-21-2006, 10:24 PM
o2man98's Avatar
I would just like to add that the PI really is a great gasoline additive. I put it in the Silverado and it really does take the start up rattle away. I treat about every third or forth tank of gas.
PI Additive: http://www.amsoil.com/storefront/api.aspx?zo=1436102
As for the Powerfoam in the booster line, you are at your own risk. I do not doubt that this would have some MAJOR cleaning effect. This stuff is a STRONG cleaner. I have seen this stuff sprayed on carbon covered snowmobile exhaust power valves and piston tops and it makes the carbon simply wipe off.
Power Foam: http://www.amsoil.com/storefront/apf.aspx?zo=1436102
I do highly recommend the PI additive. I always thought additives were monkey business but this one I have experienced it working.
Old 11-21-2006, 11:44 PM
~RedLineLs1~'s Avatar
Just curious, but can you get the power foam at most part stores? It might be something I'm willing to try.
Old 11-22-2006, 02:39 AM
SHINER's Avatar
power foam through the brake booster...and nothing but good results...FWIW
Old 11-22-2006, 07:40 AM
Pharm0r's Avatar
fuckit. ill try it i mean...not like ls1s are expensive or anything.
will do my next tuneup
Old 11-22-2006, 11:16 AM
SpdFrk1990's Avatar
Now like anything would happen and if it does you can go buy a ls7 they are pretty cheap also.
Old 11-22-2006, 02:14 PM
V6 Bird's Avatar
You guys are ******* gay with your Sea Foam crap..that is all. Right David? lol
Old 11-22-2006, 03:47 PM
TX_SS's Avatar
it was fun...
Old 11-22-2006, 05:34 PM
o2man98's Avatar
You will not find the AMSOIL Power Foam at many parts stores. It is best to order from one of the above links and you will get it factory direct. Besides, doing it that way helps to support LS1tech.com.
Old 11-22-2006, 11:01 PM
LS1MONSTER's Avatar
They have Power Foam and then there is Engine Flush. Has anyone tried the Engine flush? Would a person use both of these items for maxium effect?
