What Is Causing My P0307 Misfire?!?!?!?
1) I replaced the plug. Old plug looked good, only had about 3-5 months of life. cleared the codes and ran engine, still sloppy and puts out P0307 again.
2) Swapped entire coil pack rail with ls1powerhouse's rail. Inspected old pack and looked good. cleared the codes and ran engine, still sloppy and puts out P0307 again.
3) Swapped coil pack #7 pack on my rail with the first one. cleared the codes and ran engine. P0307 DAMN!!!
WHAT CAN I DO NOW??? Seriously people, I need help.
My car is running really sloppy and is smoking like crazy.
How do I run a fuel ingector test on #7?
Do ya'll think it's my valve spring seals? I've put about 16-17K miles since i got the car last FEB.
How can I tell if my seals are bad if I take the valve cover off?
Jerry
when oil gets into the cylinder, its usually from bad valves, rings. and the fact that its #7 cylinder makes me think of the 3
#7 ringland problem. esp it the injectors were clogged up to begin with
!!!!) Which by the way it was hard as hell getting that tool hooked up properly. After the compression test we (my friend Grant) found the problem. I took the plug out and it was GUNKED, It was full of oil and carbon deposits. #8 was inbetween 160 and 180 psi. #7 didn't even brake 30 psi... I'll be taking the engine out next saturday, new piston and rings. Well since the engine will be out....
forged/spray or heads and cam?Really, thanks to all that put their $.02 and info.
Jerry
Sorry that this is such an in-depth problem for you. Whenever I read this posts I always hope it's just a plug or an injector or worst case, a pushrod. Personally I would go with heads/cam but it depends on what you want to do with the car.
