Sponsored by: CARiD
steering wheel shaking
Old Jan 14, 2007 | 05:06 PM
phoenixv8's Avatar
Default steering wheel shaking
I have noticed that my steering wheel has started shaking when Im driving at speeds over 55 and in the highway. Could it be that the wheels need to be balanced. there are alot of pot holes where i live.
Old Jan 14, 2007 | 05:55 PM
JD_AMG's Avatar
Could be unbalanced wheels, need of alignment, or could be warped brake rotors(do you have the stock ones still?).
Old Jan 14, 2007 | 10:37 PM
MEZA TA's Avatar
Sounds like time for a balance and alignment to me.
Old Jan 15, 2007 | 01:14 AM
ksuburban's Avatar
ballance your tires
Old Jan 15, 2007 | 10:35 PM
phoenixv8's Avatar
i think i will balance my tires on wednesday. i'll let you all know how it turns out. thanks phoenix
Old Jan 15, 2007 | 10:54 PM
redramair98's Avatar
sounds like a balance, bad rim or bad tire belts shifted etc
Old Jan 16, 2007 | 11:40 AM
BigDaddyBry's Avatar
Mine would rattle but under different conditions. Fixed it by tightening the bolt on the steering knuckle (don't know if thats the official name, but its located just to the right of driver's side exhaust manifold if you're facing your car).
Old Jan 16, 2007 | 11:14 PM
99corvette's Avatar
you could have dented a rim, this happend on my C5
Old Jan 16, 2007 | 11:51 PM
JohnnyC's Avatar
+1 on tire balance - this is usually free if you go to the place where you bought the tires. If not, expect $5 per tire typically. If you get the tires balanced and the vibration still happens, then you are looking at other factors like bent rims, broken belts in a tire, broken suspension parts, ect.
Old Jan 22, 2007 | 04:52 PM
ROB2000's Avatar
im having this problem to. i noticed a slight vibration at 80 mph or higher, but now i replaced 2 rear tires with 255 instead of 245 as that was all they had and it was closing time. so one rear tire went up front, and now the vibration is very bad at 45 mph, seeing this thread and asking another person, said rebalance the wheels, i did the fronts but its the same. i cant notice any damage to the rim or tire. so im not sure what else is wrong. my power steering is dying, but it should not shake the wheel like this i dont think, as it was not doing it till i moved the tire. will the 2 diff sizes cause this issue? or just make it more noticeable. they were used and the tire dude assured me it would be fine. but im wondering now.
i dont mean to jack you thread, but i think its silly to make a second thread with the exact same topic.
Old Jan 22, 2007 | 06:07 PM
koolaid_kid's Avatar
Vibration is normally an out-of-balance condition, which could also be caused by a bent rim or a poorly made tire. IIRC, under those conditions they will not be able to balance it at all.
Old Jan 22, 2007 | 06:12 PM
ROB2000, you just cannot do that (put 2 different size tires on the same axle). At best, it is dangerous.
Old Jan 22, 2007 | 06:54 PM
99corvette's Avatar
Another thing is guys, sometimes you rim can be warped, and you wont be able to see that. I bought some brand new Z06 rims and before i had tires but on them, they tested all the rims on the balance machine, and one rim was actually warped.
Old Jan 22, 2007 | 09:05 PM
sdm1234's Avatar
wow ive never heard of that before? i wonder what causes that? probably smokey and the bandit type stunts haha.
Old Jan 22, 2007 | 09:36 PM
Stang-Slayer's Avatar
if ur steering is real loose.....make sure ur bolt on ur rack & pinion is tight....Mine was loose and has REAL LOOSE steering
Old Jan 22, 2007 | 09:51 PM
ROB2000's Avatar
i meant 2 bigger tires in the rear, and the smaller ones up front. i wasnt to keen on it, but it was all they had at the time, my other tires were not salvageable. ill look at the tires again and make sure i did not quote the wrong size. i know the 2 front are 245/50/16 . ill check the backs in a few minutes after dinner. (im on a **** poor budget if you cant tell) the rear are 255/50/16 is that really a problem? i see pizza cutters on cars and huge tires in the back that makes the car tilt, i did not forsee this being a major problem.
if the rim is damaged how the hell can you tell if its not obvious?, they balanced them, and did not say anything about a problem. maybe ill try another shop and see.
i would not say the steering is loose, but i have to oversteer to get the same results. its a huge turning radius.
this was even before i replaced the tires.
which bolt are you referring to to check? im not familiar with the unit as for as tightening it up.
Old Jan 23, 2007 | 12:31 AM
Must have been made in China.
Old Jan 23, 2007 | 02:50 AM
ROB2000, there is no issue with that, as long as your ABS light does not come on. If the sensors realize that one axle is turning faster than the other, the car will disable the ABS. There is a percentage of size that they need to be within each other, but I don't remember exactly what it is. Somewhere around 96-97%. But I ran exactly what you are running, and had no problem at all.
So, I would say that you have a steering issue, from your description.
Old Jan 23, 2007 | 02:57 AM
delinquent543's Avatar
check ur tire pressures.. too low or high might cause an issue.. seems like it wont help but it fixed my problem
Old Jan 23, 2007 | 04:24 PM
ROB2000's Avatar
ill check the pressures again, i set them all the same when i swapped them out. im thinking part of its the rim, as it has a big balance weight and a small one, i know it dont always mean something. but since the problem became very pronounced at a lower speed. i think its that. i cant see nothing wrong with the tire. dunno if some suspension went bad. also will wheel bearings cause this? i want to fix the cooling issue and power steering, but right now this became the most important thing as shes all over the road and its a little worrying to say the least. luckily im close to work and school. but dont have the funds to switch things out without knowing if its the problem.
