Sponsored by: CARiD
heater problems????
Old Feb 15, 2007 | 06:36 PM
bigbadbowtie94's Avatar
Default heater problems????
dont know if this the correct post but here it goes... i have a 95 Z28, the car was just bought not long ago and the heater barely supplies any heat.the blower works so thats not it. i tore apart the entire passenger side lower dash to get to everything. i checked all the vacuum lines and any other visible signs that could be causing this. then i took the heater core cover off and felt the heater core, i could touch it with my bare hands? shouldnt it be as hot as the antifreeze running through it? is it the heater core has a problem or is there any other common problems that the f bodies suffer in this department? any help would be greatly appreciated, its way to cold to drive around without heat.
Old Feb 15, 2007 | 07:21 PM
taintedmeat's Avatar
Could be the t-stat, or some kind of blockage in the core.
Old Feb 15, 2007 | 08:56 PM
Unhappy
the thermostat would just cause it to heat up slower tho wouldnt it?
Old Feb 15, 2007 | 10:42 PM
ZeeVert's Avatar
This is going to sound silly, but I have to ask... did you check the radiator level and not just the overflow tank? (It sounds like the heater hoses were hot, so it's probably not this.)
Old Feb 18, 2007 | 11:50 PM
6Speed_94Z28's Avatar
Id say you got a coolant blockage, did this on a 94 Z28 I bought at a sale one time. Flushed the system and it got extra warm. Id say that would fix your prob.
Old Feb 19, 2007 | 12:36 AM
fuseone's Avatar
no because if it was a a thermostat problem the thermostat would not open which in turn wouldnt allow it to flow
Old Feb 19, 2007 | 11:48 AM
coolant level is good, i guess i just might try the flush on it. so you dont think it has anything to do with vacuum lines then?
Old Feb 19, 2007 | 12:26 PM
Well I would try flushing it first, heater core prob has blockage in it, small piece of trash can cause it.
Old Feb 23, 2007 | 07:22 PM
frapjap's Avatar
Did anyone ever find out what was wrong? I'm considering purchasing a '94 with the same problem....
Old Feb 24, 2007 | 01:27 AM
well still havent got around to the flush yet, but prolly monday afternoon. i have talked around alot and im pretty positive thats what it is. but weathers been good lately and i didnt need heat so i wasnt in a hurry. i will let u kno if it works or not.
Old Feb 24, 2007 | 07:41 AM
frapjap's Avatar
Thank you! I do appreciate it. Hopefully that will be my problem too!
Old Feb 24, 2007 | 02:21 PM
Black99TransAm's Avatar
i have the same problem... i have a 160* stat, and the heater doesnt work at all...
Old Feb 25, 2007 | 11:59 AM
tsgtv6's Avatar
haha. Mine's doing the same thing lol. I've got a 94 Z28 also. I'm gonna see if I can't get around to that today then post something. It's too damn cold to ride to work like this again lol.
Old Feb 25, 2007 | 09:58 PM
tsgtv6's Avatar
I went out and bought some Zerex 10 minute flush, and a flush kit today and changed mine out. When all the fluid came out it was a nice baby-**** brown lol. I also changed the thermostat while I was at it. It blows HOT now. I'd try that. Just don't do it in the freezing *** rain. That's always fun.
Old Feb 26, 2007 | 02:50 PM
well today i hooked the car up to the snap on fluid flusher. well..... pain in the a$$ it was, leaked fluid all over everything, luckily the opti apark was spared. But the birght side was yes i did get the coolant changed, the bad my heater only blows about 15 degrees hotter than before. I give up!!!
