Dexcool or the Green Stuff???
Dexcool is corrosive to Aluminum and likes to gel up
The only reason GM still uses it is because of the insane amount of money they spent developing the stuff.
Has anybody heard the same things? Every other vehicle that's not GM uses green and seems to be just fine. Has anybody changed fluids in their rides? Just curious... I will be replacing a power steering cooler soon and then would be a good opportunity to switch if it were for the better.
-J
I will never put green stuff in any car that came with dex. It's supposed to take dex, I've been using dex in all my current cars since new, and dex has never caused me a problem.
There is nothing wrong with dexcool. What is wrong is the 5 year/150k change interval that GM recommends. I change mine every 1-3 years (depending on the car) and never have any issues.
Think green can't cause damage? Think again. Leave that stuff in too long and it'll eat through cooling system components just like dex would. I've seen green eat through everything from water pumps, to heater cores, to radiator cores, to plastic coolant overflow bottles.
Whatever coolant you pick for your LS1, change it every 2-3 years and you'll never have a problem.
When you run into real problems with dex is when you either let the system run low on coolant (introducing a lot of air to the system) or let the coolant get too old. Either of those circumstances can cause the dex to get sludge or gel like.
Don't let the system run low, and change it out every 2-3 years and you should be fine. The same is good advice for the green as well. Only reason why I prefer dex is because, when changed regularly, my cooling system internals seem to stay cleaner than they did with the green stuff (also changed regularly). On my older cars, Green stuff has always left a grayish-white cement-like coating on the inside of my radiator tanks even when changed every 2-3 years, by dex never does that on my newer cars.
Thanks guys
the PERFECT example of this is the pontiac vibe/toyota matrix. for those of you that do not know, GM and toyota got together and made an engine. it was a 4 cylinder - very nice engine. the engine was to go in GM's pontiac vibe, and also, toyota's matrix. the cars are almost identical, just like the camaro and firebird, with a difference in outside styling. maybe a few other things (my mom has a vibe - nice little SUV that gets 34 mpg). GM says "only dexcool should be used in this motor." toyota says "NO DEXCOOL!" so, why would GM say you have to use a coolant in a motor when toyota runs the EXACT SAME MOTOR AND TELLS YOU SPECIFICALLY NOT TO USE DEXCOOL?! because dexcool is trash and toyota knows it. GM just needs the money, so they scare you into using it.
as a point of reference, honda absolutely FORBIDS dexcool in their cars. FORBIDS IT! they are LIVID about this stuff. toyota is, too. while not as bad as honda, toyota forbids its use in many of their automobiles as well.
here is a VERY REPUTABLE article posted on the boards absolutely lambasting dexcool for being the junk it is:
https://ls1tech.com/forums/showpost....37&postcount=1
you could be a dexcool fan, a dexcool hater or someone that doesn't care at all, but this article is GREAT information, and you can't argue with the source. chances are, they know a lot more about the stuff than any of us.
numerous articles have been written about dexcool. it is trash. GM uses it because they have invested an obscene amount of money into its development, so they basically force you to use it with all kinds of scary warnings so they get your money.
there's plenty wrong with dexcool. yes, the change interval is definitely its biggest problem, but also, the lack of corrosion protection for the first few thousand miles and the particularly nasty habit it has of eating gaskets due to its organic nature are other problems, too. remember when GM started using dexcool? they had to redesign their head and intake manifold gaskets because certain cars were blowing them left and right. the dexcool was eating right through them, or rather softening them up so much, they would fail. it still does that to this day with rubber seals. dexcool ate the seals in my water pump and caused it to leak all over/have a nasty squeeking sound due to the bearings being shot - and my car was 5 years old/had 30,000 miles - well within the recommended change interval.
yes, green can. however, its change interval is 2 years. if you don't change it out within 2 years or so, then anything that goes wrong is your fault, not the fault of the coolant, just like dexcool can't be blamed for anything that happens after 5 years/150,000 miles - you were warned to get it out of there. the fact is, green is a much more proven coolant than dexcool, and you're much less likely to have problems with green within its change interval than you are within dexcool's.
exactly what i'll be doing. i switched to green almost 10,000 miles ago. so far, no regrets.
I've owned enough dexcool cars to know that nothing is wrong with the stuff if you change it as often as you would with green. I've got a '96 Bonneville that's been running dexcool for 11 years now without issues related to the coolant (no corrosion, no gel, no gunk, stock radiator is clean as a whistle on the inside). I get it flushed every 2-3 years.
As for it not protecting the engine from corrosion for 5000 miles (true or not), this has not caused me any issues. I've actually never put 5000 miles on any batch of dexcool in my Camaro or Trans Am because I don't drive the cars often enough to reach that mileage during my change interval. Oddly enough, I don't have any cooling system issues on my '98 car that is now 9 years old with a 100% stock cooling system, and when I sold my Trans Am at 4+ years old, that one had no corrosion issues either.
You can praise the green stuff all you want. My own personal experiance is worth far more to me than any articles or info posted from any source. IMO, it's all about proper change interval and the reason why so many people see issues with it is due to following GMs flawed advice of a 5 year/150k change interval. People get it in their head that this stuff can actually last that long, therefore they wind up with issues. I'll bet that's why other OEMs won't let people use dex in their cooling systems that are shared with GM, because they don't want their customers thinking they can leave that stuff in for 150k.
Just seems odd to me that if dex is SOOOOOOOOOOO bad, why is it that I own 4 cars at the moment with dex (and have had many others), but I never have any premature cooling system issues? Or gunk build up? Or gel? I'll tell you why. Proper maintenance (meaning more regular change interval than recommended). It goes a long way.
Here is what I've seen personally: Dexcool changed every 2-3 years = no premature problems, no corrosion, no gel, no long term issues year after year.
sunny d
