Rattle sound on acceleration
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
I haven't driven the car much over the past 4 months but prior to January it was my daily driver. Since I've parked it I've done a little work on it that needed to be done.
Changed spark plugs
installed a new custom Y pipe and a B&B catback
and a few other odds and ends.
Last week I drove the car a few times and I can hear a rattle coming from the car. From what I can tell it seems to be located on passangerside toward the front of the car. I guess either the rear of the engine compartment or under the front passanger floor board. I thought it might be the Y pipe at first but the bolts on the flange are tight and looking over the exhaust I don't see any place that it's rubbing. I don't think this rattle was here a month ago but who knows now that the exhaust is quieter it might have been. All the work I've done has been with in the last month and the rattle is pretty loud. I can't seem to get the rattle to occur all the time it will only do it at times and sometimes when I slow down with the car in gear.
I just need some suggestions on items I could check.
Car has all the mods in the sig along with subframe connectors.
Changed spark plugs
I had a rattle under my driver floor board... it did the same thing only sometimes... at a low rpm... and if i would go close to a building or drive threw u can really hear it.... which helps whith a loud exhaust.... so i took it to the dealership and they said that sometihng was messed up with the 02 sensor causing it to rattle.... fixed that problem....
My SES light came on around the time that this rattle started but I replaced the 02 with an extra one I had from when I did my header install. The rattle is still there and it's loud enough that I can hear it with the windows up and the radio on. Someone else suggested a heat sheild too.
i think its time to start playing around with the exhuast... just try hitting it when its cool.... or if u have access to a lift put it in the air... hit it a few times if u dont hear it... start it up n try to figure out where the rattles coming from
Originally Posted by ws6nick
Is it a high pitched rattle or a dull rattle?
Originally Posted by ShevrolayZ28
What was the code?
Originally Posted by JD_AMG
Probably the metal piece that connects the 02 wire to the 02 sensor itself. Mine rattles from time to time.
