WTF?? Help!
So I replaced the front o2's with bosch 13111's yesterday and it seemed fine everytime I took it out. I thought that might have been the problem so I was relieved that it was running fine. Until tonight I left to go somewhere and low and behold it stumbles again, when giving it gas the rpm's drop and it wants to die, then finally gets gas and takes off. So the o2's weren't the problem after all since it is still doing this and no o2 sensor codes..
any ideas on what it might be? I have cleaned the MAF but that doesn't seem to help. Also I was planning on doing a cam install soon and then getting it tuned so when the tuner I go to does the tune would he be able to tell maybe what it is or not? I don't want to do the install and then my car still runs like sh*t.
sorry for the long post.
any suggestions are greatly appreciated.
Also, it's possible that you might be having fuel injector problems. My Z28 would sputter and then start going, blowing black smoke and unburned fuel, but only if it was a cold start. Happened to be two clogged injectors on the passenger bank, which caused a lean condition on two cylinders and rich condition in the other two. Lastly, just an idea, the fuel filter could be clogged, not allowing enough fuel.
If you have any codes, post them up. Hopefully you'll get some soon, which willl make things easier.
and as far as the fuel filter goes, that shouldn't be the problem I just replcaced it about 5,000 or so miles ago.
Look into the history of what?
alright I will see if he can look into that
also is there any possibility this could be a small vacuum leak? would that cause problems like this?
