- Chevrolet Camaro 2010-Present: How to Replace Your Power Window Actuator
Step by step instructions for do-it-yourself repairs.
Browse all: Chevrolet Camaro or Pontiac Firebird Exterior Guides
How to replace your power window motor...
If it was working well until two months ago, then I don't think the factory wiring configuration (which has been in place for 2+ decades) is the answer here. Could be that the track is still gummed up and it needs some cleaning before additional lube would bring it back to previous operational speed.
The AutoTrix kit was once a popular thing to do, but I find it's value to be questionable.
Thanks for the reply, that makes sense. As for the tracks, they seemed a little dry, but not overly dirty (car has been garaged or covered it's entire life, almost never driven in the rain or snow).
Anyone know if how hard I tightened the bolts for the motor to regulator connections might have something to do with it? I noticed after the replacement that on the old motor that it looks like the part of the regulator with the gear teeth was rubbing on the housing of the motor as it spins, so am thinking if I tightened the bolts too tight, the part of the regulator might have too much contact against the motor housing?
~The Troll~
It was easy. I'm glad I decided to do the entire regulator. It probably took me a minute to pull the thing out after drilling the rivets.
I scrapped the rivet method with 1/4" stainless bolts and went with stainless washers to give the fiberglass the backing it needs.
So, my thought was that the rivets don't get the regulator tight enough in place and allow it to "float". This is coming from a new, never replaced factory riveted regulator on a 35th with less than 8k miles on it, so it's not like it had 100k miles to loosen up.
I'm surprised yours would be loose at just 8k miles.
I did check for any sort of travel after the install and it was solid with no movement. I also used blue loc-tite. Hopefully it works out for me and given the information that you've provided in your response, I will pull the door panel in the future to check for any sort of issues.
https://ls1tech.com/forums/general-m...-included.html
