Sponsored by: CARiD
A/C Delete
Old Sep 21, 2007 | 12:16 AM
bww3588's Avatar
Default A/C Delete
tuesday im going to remove my A/C. i have one question. is there any alternative to the evap/heater box? i want to remove all that to give more access to the #8 and what not. right now, i can only see cutting the lines and crimping them. if i **** with it im afriad im going to ruin my airflow across the heater core and my heater wont work right.
Old Sep 21, 2007 | 07:22 PM
snake charmer's Avatar
i just would unbolt it and leave the part with the two wholes sticking out . might want tto cover the wholes that way they dont rust up over time .
you will be surprised at how much easier it will be to work on that side of the engine bay .
Old Sep 21, 2007 | 09:46 PM
bww3588's Avatar
just unbolt the evaporator housing from the firewall? i still want to retain my heater.
Old Sep 21, 2007 | 11:26 PM
the_merv's Avatar
Veteran: Air Force
Here ya go..
I'm still tryin to find the ones that I have with the Pics of the Box behind that Panel, where I cut it..
https://ls1tech.com/forums/appearance-detailing/711614-ac-delete.html
https://ls1tech.com/forums/appearance-detailing/713330-ac-delete-panel.html
Old Sep 22, 2007 | 08:52 AM
the_merv's Avatar
Veteran: Air Force
Nevermind..the first link had it..
Old Sep 23, 2007 | 02:33 AM
bww3588's Avatar
PM sent merv
Old Sep 25, 2007 | 02:42 AM
bww3588's Avatar
ok, well i took everything off tonight except the evaporator box. i see it has to come out through the inside.....damn....anyways, there is a ton more room under the hood now and it looks so much better.
1 question, when i get the evaporator box and evaporator off, how much do you think i could sell the entire A/C system for. i mean everything from evaporator to condenser, to compressor to accumulator with all bolts, brackets and lines in between? i seen Harrison V5's going on ebay for around 200 bucks.....so idk.....is **** like this easy to sell? whats the deal?
Old Sep 25, 2007 | 04:38 AM
EightBallZ28's Avatar
Default AC Delete
Do ac's on ls1's need a new pully or bracket when you remove the system? Or are the ac's electric?
Old Sep 25, 2007 | 04:58 AM
bww3588's Avatar
it runs off its own belt.
Old Sep 27, 2007 | 07:53 PM
Flamin' bird's Avatar
I would like to finish removing my a/c and the only thing that is left is the box in the back. I'm trying to find out if I remove that will I still have a working heater?
Old Sep 27, 2007 | 10:54 PM
bww3588's Avatar
look at the links the_merv posted. these are blockoff plateds for the evaporator box that has provisions for the heater hoses.
Old Sep 27, 2007 | 11:02 PM
waterbug1999's Avatar
Are you guys pulling it out from under the dash?
Old Sep 28, 2007 | 12:53 AM
bww3588's Avatar
i dont think you have a choice.....there isint enough room under the hood.
Old Sep 28, 2007 | 12:24 PM
I just cut mine, from under the hood flush like the link you posted. After that just seal it up. I still have heat but if you remove the whole thing, you wont have heat though.
Old Sep 28, 2007 | 10:11 PM
bww3588's Avatar
cut? i thought you just unbolted the evaporator box and pulled it out. i thought the blower motor and heater core was seperate from the evaporator housing.
Old Sep 30, 2007 | 02:07 AM
Im no expert, but I took bolts out here and there and then said **** it, and cut and sealed it.
I think the whole thing is one pieace pretty much. The blower, doesnt it blow AC and Heat, just depends on your settings? Im not an expert, but if you get rid of that, you wont get anything. And, the ducting inside the car is the same for AC and heat.
Old Oct 3, 2007 | 02:38 PM
So did you finish this up?
Old Oct 4, 2007 | 06:11 AM
bww3588's Avatar
im still waiting on a straight answer......
Old Oct 4, 2007 | 12:17 PM
Whats the question?
Old Apr 9, 2008 | 04:14 PM
bww3588's Avatar
k, ***** getting intense....the motor is out and this weekend ill be making the block off plate and getting it sealed up.
