shaking and vibration at about 50-70 mph
might be a bad bearing on either shaft in the rear...or can be a front wheel bearing assembly in the front...can be real pricey,,,but prolly if it starts at 50...then it has to the either front wheel bearings...
My ride had been running perfectly smooth as far as I could tell, until I had the tires rotated. After that, prrt, I got the shaking that your taking about. I knew from the past it was going to be a wheel off balance. I litterly just got back from the shop, all 4 were out of balance. The car is as smooth as a babys bottom now.
It was wierd though, how I didnt notice a problem until the tires were simply rotated. strange.
Definetly check the balance of the wheels 1st.
