What Motor Oil & Oil Filter are you guy's using?
#102
#108
I have a little over 60k on my motor, once I fix the oil pan leak I'm switching from conventional valvoline 5W-30 to a synthetic 0w or 5w-30. Not sure what brand yet though, but I have a week to think about it!
I'm using an AC delco filter right now but may use a supertech next time.
#109
hate if you want but i use supertech full synthetic 10-30 and delco filter. read a thread that said supertech is as good as mobil 1 and ill have to say that may be true i have GREAT oil pressure with it and the filter and oil always comes out pretty good.
#114
i use a thicker grade oil because i have so many miles on mine...if your not burning any oil then i wouldnt worry about it but it wouldnt hurt anything to switch to conventional 10W-30 either IMO
#115
Why not?
#117
I use GC 0w30 with the STP equivalent of the AC Delco PF59 filter (oversized... and Autozone doesn't ever have the PF59 so I look it up in the xref section of their book every time) and PCV "fitting" 12572717. I get some oil burning. Want to switch to the LS6-style PCV system.
Do not use Fram except for the "extended guard" NOT to be confused with "extra guard." All of their others suck. I recommend AC Delco or STP because they are good and cheap. There are better such as Mobil, K&N, etc. but they are 3-4x the cost.
http://www.corolland.com/oil-filters.html
http://www.knizefamily.net/minimopar...ers/index.html
#120
