Ticking noise coming from right header?
I just had some budies put some pacesetter headers on and their has been this ticking noise coming from the right side of the engine. Are pacesetters infamous for leaking. (This is facing from the drivers seat.) I had the headers retightened but the ticking noise only occurs when my car goes into over drive and a play with the gas pedal. otherwise it doesnt tick when its not in overdrive. I
Factory gaskets are actually known to be a bit better than the aftermarket counterparts. Does it only happen when the car warms up? If nothing else really works, go ahead and get some decent aftermarkets. I personally have factory ones and I have no leaks.
*Edit*: Just thought about this; it might not be the gasket where it joins the heads. Check the collector.
First you need to determine if it's from the flange or some place else. If you have re-torqued the bolts as recommended then you may have a gasket issue you didn't catch or it's coming from where the headers and the ORY meet.
I have the exact same leak on my 00 with Pacesetter LT's. I've solved all the leaks from the headers to y-pipe and cat-back but still have the ticking. I have the factory replacement GM gaskets in mine as well. I just bought the Percy "crushable" style gaskets. I had a friend who used them after an accident that bent and crushed his slp headers (not LT's) on a 3rd gen firebird and his doesn't leak at all since. Not sure if that helps but I can let you know if it fixes mine when I'm done...won't be for a bit since it's still snowing here in maine
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Uhh.... NOOOOOO!!!. You never WELD headers to the block. You can weld them to the y-pipe (still not recomended), but certainly not to the block. I don't even know how you would get up in there to weld it, but nonetheless the general rule is: NEVER WELD ANYTHING TO YOUR ENGINE BLOCK!
I think I have the same problem, I don't know if it's the shitty pacesetter y-pipe merge making that sound, or some kind of leak. But when I pop it into 5th at 40 and go WOT, it sounds like an **** seepage leak
This wouldn't be a tick mainly heard from the right side of the vehicle at idle sounding similar to a lifter tick and going away around 2500 rpms would it? The sound is easier to hear behind the tire around the fender and almost under the car???? If this may be the annoying tick I'm experiencing I may not bother with the header gaskets.....
Shure you can welding stainless and aluminum is somthing welders do all the time.
