Low oil pressure on 2000 camaro v-6
Well my friends 2000 camaro v-6 started making a ticking sound at start up, and his oil pressure was lower than normal. So we changed the oil pump,timing chain, and all gaskets, and the oil pressure is still low!!!!
Pressure is normally below 60 psi when the car is running and it only goes to the second dash on idle. Im not sure what the normal pressure is for v-6 camaros. What else could be the problem? bad sensor? fuses?
Normal for a 3.8 is somewhere around 12 o clock at idle, though slightly lower is not unacceptable. What does it read under load...at cruise?
I would swap in a new pressure sender and see what it reads..to begin with anyhow. Failure of those is not unheard of.
