Possible Bad head gasket?
I checked the dipstick and it isn't foamy or white, just the standard dirty color indicating that the oil needs changed, but it seems like the oil is over full by a bit. It doesn't have an anti freeze smell that I can determine, but when I start it up, there's white smoke from the exhaust (rich smell, but not really a sweet, sickly smell).
It runs fine from what I can see (no visible loss of power) and the white smoke seems to disipate after a little bit of driving. I have an inspection coming up this week and i'll have them do a pressure test and an oil change while they're at it, but I wanted opinions from some folk on what it might be. It doesn't seem to have all the signs of a bad head gasket. Thanks in advance.
Im guessing a head gasket or both.
I do know the radiator was extremely low. It drove perfectly fine the 20 miles to the tire store, but once there, it went kaput. It is startable and driveable, but I don't want to cause any damage. (plus it sounded horrible the brief amount of time it was running)
It looks like I may have to part the car out at this point because frankly, while i could come up with the cash in a pinch, theres no guarantee something else is wrong that they may miss.
It's pretty sad too, because the rest of the car is in great shape. 95k on the car, new tires, interior is clean and fully optioned with T-tops, 6 speed
I'm not sure what im gonna do about it quite yet. I just figure with the amount its going to cost to have the top end worked on, in the long run its likely cheaper to order a crate motor and go that route. The 6 speed just had the clutch done last year and everything else is fine, its just the motor that holding it back now.
edit: and thanks, if you were closer, at least one of us would know what to look for
I HAD to get a jasper motor due to my cars warranty from the dealer...im not unhappy at all...100k mile warranty to beat on my car and it runs like a champ now
fuel injector wires so that over time, the head gasket got burnt and leaked. No idea if the head itself took damage, but the gaskets need replaced. Everything else checks out fine so its a matter of new gaskets and possible a new head.
I was looking at some performance heads by edelbrock. Anyone recommend some decent yet affordable heads? I priced the edelbrock at ~460 bucks each.
