car hesitation
If this is part of the issue, you'll get the problem under acceleration, no matter the gear. You should also make sure your fuel filter is good. (I had a problem with both at the same time, which just magnified the issue.)
GM claims K&N filters foul the MAF with oil. K&N claims the sensors leak silicone on the elements. Whatever the cause, cleaning the MAF is a cheap/easy thing to do/try.
