p0300 Need Help Plz!
I will start off saying Bank 2 LTFTs are are 25% and all the spark plugs were completely black and you can see the gas coming out of the tail pipes. I changed the plugs and wires with MSDs and NGKs TR55 about 2 months ago so I thought maybe that was the problem and have switched back to the stock plugs and wires but that didnt help. I also swapped O2s and reset the battery but that did not help either. Mods are headers intake and stall on stock tune. Thanks for any help.
thats a fairly common code for cammed cars but i see youre not cammed. i would say double check youre wires and make sure theyre all connected. also did you gap youre plugs? and make sure the coil connectors on on too. i wouldnt really worry about it unless it points out a perticular cylinder like po301 to po308.
If your ltft's are that high look for a vaccum leak. on that side of the motor i.e. the air pump tubes going to the manifold. I had that happen a few months ago those vac tubes get brittle and break easy.
p.s. a cheap way to trouble shoot is to cut a thin piece of metal and sandwich it between the emissions fitting and the air tube(if your headers have emissions provisions that is..) if that brings you ltft's back down you found your problem and just by some block off plates so it won't happen anymore. that extra air going by the 02 sensor really messes with stuff. Oh and is the car running okay or does it jerk and sputter?
it is most likely and exhaust leak on the passenger side where the tube goes to the top of the header. Its most likely loose.
When I had the problem that's what caused it.
I had to tighten the leak first.
swap plugs because they were fouled(all 8)I like'em all fresh
optional(wires)
I swapped 4 coils and it made it better then I ended up doing the other 4 and it fixed my problem.
btw I had the same po300 code.
optional(wires)
