WTB - Headlight Motor
Thanks in advance
to replace it is not too bad. you have to remove the black cover from around the headlights and then remove the metal cover. next remove the 2 torx bolts that the headlight hinges on and then remove the 10mm nut from the motor shaft.
there are three bolts that hold the motor in place and you need to remove them also. after that you just reverse the process for the new motor and hopefully your fixed.
you will need 2 10mm wrenches and preferably a stubby gear ratchet wrench or 2 to work in there.
You will have to kinda move the headlight up and down to get to some of that stuff also but you will figure that out.
here is a url that may be usefull for you and has a picture of the entire assembly at the end
http://www.blackws6.com/headlight/index.htm
there are also fuses for the headlight doors under the hood that may be the culprit if you have not checked them already.
Thanks again
