car will not rev up past 2k
Old 08-01-2008, 11:47 AM
95formulalt1's Avatar
Default car will not rev up past 2k
my 00 ls1 will not rev past 2k. when im driving the car it has no power. i need help
Old 08-01-2008, 12:20 PM
conan's Avatar
Is the ses light on or does it flash? Possibly a cloged fuel filter, fuel pump might be taking a dump, bad coil.
Old 08-01-2008, 04:14 PM
FatZ28's Avatar
The cats could be clogged as well.
Old 08-01-2008, 09:22 PM
ads_99ta's Avatar
what does it do after 2k rpm? does it just feel dead, or does the car die or what?
Old 08-03-2008, 08:54 AM
wickedformula's Avatar
need more information on what the car does at 2grand. I had a BMW do this to me and it turned out the cat was no good. im not saying start there but it cud be a problem. Mileage? a fuel filter as well as a fuel pump could be the issue to. lets get some more details on what the car does.
Old 08-03-2008, 09:08 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Sounds like clogged cat, there has to be an ultra restriction.
Old 08-03-2008, 11:09 AM
99345hp's Avatar
There has to be a restriction in there somewhere. Sounds like a clogged cat to me.
Old 08-03-2008, 11:20 AM
i just installd a new fuel pump.didt fix it. when im driving the car the only way to get it to go past 2k is drop in in 1st. and even when i do that theres no power. i tryed doing a burn out to see if it would do anything and has soon has the motor hit 2k it just stayed there. im lost and thinking of getting rid of it....or set it on fire lol. it back fires at 2k if u hold it and sometimes it will rev up past 4k but idk what it could be. i just did a tune up befor i installed the motor last summer and only put mayb 3k miles on since then.
Old 08-03-2008, 11:21 AM
oo and theres no light on.
Old 08-03-2008, 04:20 PM
FatZ28's Avatar
My friends 93 Z had the very same problem and it ended up being the cats. Might want to check that out.
Old 08-03-2008, 04:23 PM
SpaZMaN's Avatar
Unbolt the cats and run straight headers to see if anything changes. Also look into the cats to see if the "honeycomb" is messed up.
Old 08-03-2008, 04:27 PM
BlacKBirD25's Avatar
had a bird come in the shop i worked at before doin the same kinda thing.. cant remember if it was the muffler or the cats that were clogged up.. but ya its more then likely cats are clogged up.. just cut them off and get o2 sim's
Old 08-05-2008, 09:54 AM
ya im thinking it might be the cats. i replace the the fuel filter last night and it didnt do a thing. i have the SLP loud mouth 11 no mufler.
Old 08-05-2008, 10:52 AM
the car is also hard to start. i have to rev it to keeping it running then after a few mins its fine....???
Old 08-05-2008, 02:29 PM
snake charmer's Avatar
a bad maf can cause problems . the o2s can be a problem . that or it could be the injectors .
Old 08-05-2008, 02:58 PM
ae13291's Avatar
it is the throttle position sensor if it feels like its hitting rev limiter
Old 08-05-2008, 08:23 PM
99345hp's Avatar
yeah, i agree with the last few posts too. MAF or throttle position sensor could be the culprit. I would unbolt the exhaust right in front of the cats. If that doesn't solve it, then go after the other two sensors. It definately isn't the O2 sensors. I drove my car around for who knows how long with wires torn out of one of mine.
Old 08-05-2008, 08:44 PM
Internet Mechanic
From what I understand even if he goes WOT, its not going past it, he managed 1 4k pull at best.
When these cars go WOT the MAF is no longer a factor, the car goes to it's command tables, thats why they are tuned in speed density. MAF's factor in for part throttle and driveability.
He clearly has a restriction, I have had that happen on 3 different cars, and one bud's car with a 402 n2o motor, a after market cat popped and a baseball sized chunk had him down 80 hp....
Old 08-06-2008, 04:45 PM
the throttle position sensor is new just installed it.im going to look at the cats tonight.
Old 08-07-2008, 02:13 PM
ok its not the cats!!! i am so lost..i want to set it on fire and buy a mustang haha
Quick Reply: car will not rev up past 2k
