Sponsored by: CARiD
help me fix my ebrake
Old Sep 28, 2008 | 02:01 PM
Pharm0r's Avatar
Default help me fix my ebrake
Basically, I changed my old worn out rear pads and put in new hawk pads. Now, my ebrake kinda works but I still have to pull the ebrake ALL the way up and even then i can push the car a little.
Im guessing a fix for this would be to tighten the ebrake cable? If so how? I suppose it's simple.
thanks.
If it matters, i have a moser 9in rear.
Old Sep 28, 2008 | 03:51 PM
AFASTYZFR1's Avatar
did you try and adjust them? with the rotors off, look on the bottom of the shoes and open them up some
Old Sep 28, 2008 | 03:56 PM
Pharm0r's Avatar
I just snapped them in...what do you mean about "opening them up?" Ima go ahead and put in the SS brake lines while im at it then.
Old Sep 28, 2008 | 04:01 PM
AFASTYZFR1's Avatar
the adjustment on the bottom just prys the shoe open some more .....just pull rear rotor off and look on the bottom of the shoe....you will see a small disc with notches on it....turn it whichever way that spreads the shoe apart (can't remember which way).....if you open it up too much you might not be able to get rotor on
Old Sep 28, 2008 | 04:04 PM
Pharm0r's Avatar
Ill check it out, thanks for the advice!
Old Sep 28, 2008 | 04:06 PM
98boxer's Avatar
I belive the e-brake is self adjusted.
Old Sep 28, 2008 | 04:29 PM
Pharm0r's Avatar
Well I'll let my ebrake know that. Cus its def not self adjusting.
Old Sep 29, 2008 | 08:26 AM
wssix99's Avatar
Save the manuals!
You probably changed the rotors too, right? If so, that's why you need to do the e-brake adjustment. (They do not self adjust.) The e-brake pads need to be adjusted to the bore of the new drums in the rotors. Below are links, which may help.
https://ls1tech.com/forums/suspension-brakes/845856-parking-brake-assembly.html
https://ls1tech.com/forums/suspension-brakes/862055-emergency-brake-needs-tightening.html
Old Sep 29, 2008 | 11:00 AM
Pharm0r's Avatar
https://ls1tech.com/forums/showthread.php?t=845856
https://ls1tech.com/forums/showthread.php?t=862055
Yes, yes i did! Thanks buddy!!
Old Sep 30, 2008 | 02:16 PM
sleepinghawk's Avatar
That was good
