Mobil 1 question
If you are going to go with a 5W30 I would go with Mobil 1. But I still say go with the 10W30.
I definitely recommend Amsoil 5w30 over Mobil 1 5w30. I've seen a lot better oil analysis results with Amsoil in the LS1 over Mobil 1. Most notibly, the bearing wear (seen as lead on oil analysis) is a lot lower when using Amsoil.
For those that definitely want to continue using Mobil 1 due to easier availability though, use their 0w40 European formula, it's better suited to the LS1 than their 5w30 and 10w30, which are on the very thin end of the 30wt range (Amsoil 5w30 and Redline 5w30 on the other hand are on the very top end and are almost 40wt oils)
I thought you always wanted an oil with the narrowest span of viscosity that is appropriate for the temp range you live in.
I think I'll be doing a little more research.
However, this is only what I have read, aand not through my own testing. I'm not the oil guru you are, Patman.
well ill look into some more research an yeah it is hot in Dallas therefore ill ask somemore if the 10W30 is the way to go but what happens when u add 10W40 i now its more thick but any disadvantages in the winter opposed to summerany ignition problems
Does humitity impact oil viscosity or oil performance; i assume not?
Anyway, I played golf in 114 degrees in Las Vegas a few weeks ago; it did not feel hot because the himitity was near zero....
(Translation: Does your car care if it drives you around in Phenix or Dallas if the temperature is high in each location but Dallas has 90% humitity and Phenix has 5%?)
I'm getting to the end of my regular interval and will change my lubrication fluids soon.
(Translation - I need to change my engine oil soon).
This fluid interval is immediately subsequent to the extensive mechanical procedures designed to increase atmosheric interchange.
(Translation - This oil change followed a ported head, high-lift cam, oil pump, timing chain upgrade that makes my motor breathe better so it kicks ***)
When I submit my sample of previsouly used fluid to the anaylsis guy with 20 years of experience what can I expect?
(Translation - I'm I gonna freak when he tells me I have lots of strange heavy metals in my used oil sample that hopefully might be the result of the break-in of new parts?)
Humidity can play a factor in degrading your oil, although mostly only if you're doing very short trips, in which case you'd end up with more moisture in the oil and more iron in your oil analysis due to corrosion. It's pretty humid up here in the summertime, and yet I get my best oil analysis results in the summer, but I also do long trips every day (55 mile round trip to work). Heat and humidity is much easier on the oil than the cold harsh winter, where long warm up times means the oil gets more contamination in it and degrades faster. Plus wear metals are higher too, since the oil doesn't flow as well when you first start it up as it does in the summertime.
As far as viscosity goes, with good synthetics, they can span larger viscosity ranges such as 0w30 and 0w40, so it's not as big of a problem as you'd think. A lot of oils can span this viscosity range with very little viscosity index improvers, simply by using better base oils. The German made 0w30 Syntec is an oil like this, it spans a big range but yet does not thin out when run for long intervals. I used to be afraid of 5w30 and 0w30 oils too, thinking they'd thin out too easily, but a good synthetic in those viscosities can perform very well, almost making 10w30 obsolete.
I'm running the 0w30 German Castrol right now in my LT1, and am very eager to see my first oil analysis results on it. So far I've seen about 5 or 6 reports on this oil (one from my sister's car) and every one of them has been impressive.
I do agree with you that most 5w30s are too thin for high horsepower, but the real reason race cars use 15w50 or 20w50 is because they've got bigger clearances which need a thicker cushion, plus they often end up with more fuel in their oil during the race, so that oil will thin down a grade, into a 15w40 or 20w40. Plus they run much hotter oil temps which thin out the oil too.
Based on used oil reports I've seen, the LS1 seems to like an oil around 12-13cst at 100c, so it's a thicker 30wt to a lower 40wt oil.
This is why when someone does decide to do extended intervals, you should run the first interval with the new oil at about 3-5k, then do the extended interval after that, this way there is no other type of oil in there mixed in with it (when you change your oil, no matter how long you let it drain you'll still end up with 1/4 to 1/2qt of the previous oil in there, most of it stuck in the heads, oil pump, corners of the oil pan, etc.)
