New Edelbrock LSx Intake Manifold at SEMA, claiming much more power than FAST
#182
OWN3D BY MY PROF!
Looks like a LS1 to me. Cathedral port heads and an alternating runner pattern. Unless it's some odd SBF head.
#183
the part that is throwing you off are the covers that are hiding the coils and valve covers , and their 2 piece water pump
look closely at the header bolt pattern and front shot of the head
#186
If they come out with a version for the L92 heads I will do whatever it takes to fit that under my hood. I have a high stalled car that is raced a lot and is driven on the street once in a while. The power this makes in the upper rpms is exactly what I have been waiting for.
#187
dude get your eyes checked out !!!!!!! thats a LS series motor , there isnt any doubt of that
OK you are right, the covers looked like a big block valve cover to me and I know they are making this kind of intake for different engines.
Either way, it will work great on my Nova. I will keep my fast 90 for the T/A
#189
just be lucky they made the LSx covers that small , you should see the fords they have , they are as BIG as TEXAS , LMAO
just measured my 04 gto , and from the stock LS1 valey cover to the lip on my cowl is 10 1/2"
didnt have anything that would fit fender to fend to measure the hood clearance at the front
but my BMR strut brace would have to go , but so far looks possible under a gto hood
#192
I have a Sunoco hood so I could probably clear there, but think about how much of the engine is under the cowl. There is no freaking way unless I am missing something that this thing is gonna clear the cowl.
Maybe its an illusion because I have never measured from the valley cover to the cowl but it just doesnt look like its a go.
#199
At least there won't be an endless thread(s) on heat soak with this one because of the air gap with an aluminum.
more introspection of the minutia of thermodynamics would make me
I was hot to trot on the weiland, but years later I bet this comes out first (safe bet as the wiland is NEVER coming out) the problem is I dont think this will clear the lip on the fire wall for vettes.
It looks like a boat motor with that manifold on it!
#200
Edelbrock’s new sand cast aluminum LS Series Coil Covers are a great way to dress up the LS1 in your
street rod or muscle car. These coil covers are designed to eliminate the stock mounting brackets on
transplanted LS1 engines by way of fitting coils directly to the underside of the Edelbrock cover. They
are intended to create a clean under hood custom appearance and will not fit stock vehicles. These
covers accept GM #12558948 coils or aftermarket equivalent replacement coils such as MSD #8245.
Coil Covers for LS Series Engines .................................................. ......................................#4118
Coil Covers for LS Series Engines with polished finish .................................................. .....#41181
Coil Covers for LS Series Engines with black powder coat finish .......................................#41183
