New Edelbrock LSx Intake Manifold at SEMA, claiming much more power than FAST
Old 04-04-2009, 01:06 PM
  #561
redtail2426's Avatar
Does anyone know what car or truck it does fit in.People probably have not dynoed it yet because they are trying to find something to fit it in.
Old 04-05-2009, 10:42 AM
  #562
Denali08's Avatar
Originally Posted by Exotic Performance Plus
I have five of these intakes in stock. http://www.exoticperformanceplus.com...html?item=1792 $439.99 shipped. Bob
Bob,
Do you plan on doing any testing for this manifold?
Old 04-05-2009, 01:32 PM
  #563
JJD49's Avatar
The shop that I do business with just took delivery of this intake. They are going to try it out on my 05 GTO. My car is in the shop also. They told me it might fit but it may need a little trimming of material on the top section of the intake opening. There is a lot of material that can be ground down in that section. I am not sure about the wiper cowl. If needed, we can cut into that area. I will also cut my hood or replace it with a cowl hood if needed. I should know more in the next week or so.
JOHN
Old 04-06-2009, 07:03 AM
  #564
Johny GTO's Avatar
JJD49,
Gonna lose the typhoon eh? I dont blame you for going with the typhoon, it performs well and is/was 1/2 to 1/3 the price of a fast. I look forward to hearing your results with the new intake (fit, performance, etc) please take pics of it and post them. Thanks.
Good luck.
Old 04-06-2009, 03:22 PM
  #565
itsjustaSB's Avatar
yes please gives us some results on this intake and some pics
Old 04-06-2009, 03:26 PM
  #566
lt1z93's Avatar
I know for a fact it clears the cowl in a TBSS....just barely.
Old 04-06-2009, 03:33 PM
  #567
MASS seller approved
Time2Kill's Avatar
For anyone that wants to run standard LS1 style fuel rails with this, I just fabricated some stainless steel mounts for this intake. I'll have some pictures of them up later tonight or tomorrow. The fuel rails that Edelbrock sells has mounting holes towards the end of the fuel rails instead of towards the middle.
Old 04-06-2009, 07:10 PM
  #568
mOtOrHeAd MiKe's Avatar
Location: Ottawa Ontario, Canada - where arguing "DA" is for the slow and weak...
Talking
Please don't show me this...
Old 04-06-2009, 07:37 PM
  #569
Time2Kill's Avatar
For everyone interested, I WILL have a dyno posted on Wednesday, April 15th of this manifold on a Silverado SS with a 414 motor. If my tuner isn't too busy, I'll have back to back dynos with a FAST 90mm (non ported) also.
Old 04-07-2009, 12:05 AM
  #570
s/c'd cav's Avatar
sweet , lets hope he isnt to busy
Old 04-07-2009, 11:07 AM
  #571
Chief_engr's Avatar
Wink Throttle Body Fit
I'm so glad to see these getting into the right hands, I looking forward to the dyno results. One note: The throttle body boltholes are positioned to fit either the stock standard 3-bolt LS or the Edelbrock 90mm. Any 90mm throttle body made only to fit 90mm manifolds won't fit. The difference is the bottom two boltholes. You'll need to oversize (or slot them inward and down .160" on an 11.5° angle) these two boltholes so they will fit. That was the only way to accomodate the stock throttle body.
Old 04-07-2009, 11:24 AM
  #572
dman's Avatar
my stock TB bolted right up
Old 04-07-2009, 11:46 AM
  #573
dubrado's Avatar
Found out from a shop that the intake doesn't fit GTO's
It it way too tall, and it also hits the wiper cowl and can't clear that.
They said the amount of work it would take to get it to fit wouldn't be worth the money
Old 04-07-2009, 01:22 PM
  #574
EPP
EPP's Avatar
Originally Posted by Chief_engr
I'm so glad to see these getting into the right hands, I looking forward to the dyno results. One note: The throttle body boltholes are positioned to fit either the stock standard 3-bolt LS or the Edelbrock 90mm. Any 90mm throttle body made only to fit 90mm manifolds won't fit. The difference is the bottom two boltholes. You'll need to oversize (or slot them outward and upward .160" on an 11.5° angle) these two boltholes so they will fit. That was the only way to accomodate the stock throttle body.
Sounds good, thanks for the info. We'll be testing one on this CTS-V either at the end of this week or early next week. http://www.exoticperformanceplus.com...Car.php?car=29 Bob
Old 04-07-2009, 01:45 PM
  #575
Denali08's Avatar
So, it will fit a truck?
Old 04-08-2009, 07:57 AM
  #576
Time2Kill's Avatar
I'm assuming you're an engineer from Edelbrock as I was just on the phone yesterday with Dave S. talking about this exact issue, and he talked to engineering and told me the exact same info.
I've gotta say, I'm pretty disappointed that this intake cannot accommodate a stock GM 90mm Throttle body. Almost anyone that will be running this intake will likely already have some sort of 90mm throttle body with the GM 4 bolt pattern on it.
Old 04-08-2009, 07:58 AM
  #577
Time2Kill's Avatar
Fits a truck just fine with plenty of clearance under the cowl. I have some pictures of it installed that I'll be getting up in the next day or two.
Old 04-08-2009, 08:31 AM
  #578
Denali08's Avatar
I am interested to know if there is much gain with this intake compared to truck intake on 5.7 ci/TR224/TFS215/A4 truck.
Old 04-08-2009, 12:16 PM
  #579
Johny GTO's Avatar
bummer. major bummer.
Old 04-08-2009, 01:36 PM
  #580
2000 t/a's Avatar
It looks bad *** and more power is always good as long as your not cutting anything to get it to fit with how the engine sits back in the f bodies
Quick Reply: New Edelbrock LSx Intake Manifold at SEMA, claiming much more power than FAST
