New Edelbrock LSx Intake Manifold at SEMA, claiming much more power than FAST
#661
UNDER PRESSURE MOD
Congratulations you just drove a square peg into a round hole. Installing that intake on to an F body is the equivalent of removing your brakes for the weight savings. That hacking just killed the car, both structurally and esthetically. There are better intakes out there that fit guys. Although, I guess you can’t tell your friends that it makes 3000hp with an intake that fits.
#665
plus when his intake is finished it should look better and outperform most intakes on the market
#668
hopfully very soon i still gota get a tb for it and figure out the back of my hood and im changing head gaskets right now cuase i blew threw a shift on the spray and started eating coolant the # in my sig were just made a month ago with the bbk setup so it should be some interesting back to back graphs with this being the only change
#670
#671
http://www.exoticperformanceplus.com...html?item=1792
Link to these intakes. Bob
#674
Looks great, congratulations! How bad does it hit your hood? I have the same hood on my Hugger Orange Z28.
it looks like the the front will just barly clear and in the back there just needs to be a notch cut in the fiberglass where the hood meets the plastic crowl i can take pics if im not explaining it good anuf
#680
I'm trying to do my part to keep the economy going...
I should be getting the black ones in two weeks. Thanks, Bob
