People using the Greddy oil catch can...
LS1Tech Administrator
Received 1,486 Likes
Which hose size are you using? 9mm or 15mm?
Also, can you give me any idea what the height and width is of the can? Thanks,
Re: People using the Greddy oil catch can...
Anyone?
Thanks for the info
Yes, 9mm is the correct size to get. That'll allow you to use 3/8" fuel line for your connections.
Can is about 8" tall with the connections and about 3.5" x 3.5" base. PM me if you want some pics.
Where did you mount it? I know people without TCS put it where the TCS module goes, but what about the TCS cars? I'm not really sure where something of that size would fit otherwise? If you have any pics of where you mounted it, I'd like to see those if possibile....
Thanks
i remember a guy on here mounting his just to the left of the airbox or something to the metal piece that the airbox bolts on to since his car was a tcs car too, he used longer lines and stuff also. ive had a greddy can for about a year but i havent mounted it yet. im lazy heh.
