LS6 IM swap on 99 T/A
Hey guys, I'm buying a used LS6 IM from a LS1tech member. He doesn't have the bolts for the LS6 IM. I tried to look up the part #s for each bolt kit and could only find a part # for the LS6 bolt kit. (LS6 intake manifold bolt = 12552344) Does this mean they are both the same?
The question is, will my stock LS1 IM bolts work with the LS6 or do I need to buy the bolts listed above?
Thanx
Thanx
Thanx
Thanx
Heres a pic of both ls1 on the left ls6 on the right. The only differance is the bottom of the ls6 is flat which makes it flow better = more power. Also the ls6 doesn't have the egr hole.
http://www.ls1howto.com/howto/geniii...//IMAGE009.jpg
Thanx again for your help. $300 for a LS6 IM and a MTI ported TB is a great deal wouldn't you agree? Is it even possible to sell off a 99 LS1 intake? I would be happy to get anything for it.
That's what I was thinking. Just incase me or a buddy has a problem down the road I'll have it laying around. It's already got the egr plug in it too so it definately wouldn't be worth selling for like 30 bucks just to need it in the future.
Ok, so I looked around locally and cheapest I could find the front colant pipe for was like $60(want to do it today, don't have paypal/credit card to order offline). I know a lot of people on here have said there LS6 swap went well with just chisling the ribs off and using the old coolant lines. So does this mean when I do the swap I just follow the swap write up off LS1howto.com but just leave all my hoses under the IM in addition to gently flattening the tubes?
I'm pretty sure I got this under controll but if anyone has a few tips for doing the LS6 IM swap besides just linking the ls1howto.com write up I would appreciate it very much so.
Thanx in advance.
Thanx in advance.
Thanx in advance.
Thanx in advance.
Well the good news is I swapped the intake tonight. The bad news is I broke my damn oil pressure sensor...In addition to having a gaping whole in my pcv hose. So it looks like I'll be taking the intake back off tomarrow and replacing the sensor and pcv hoses. Also the car idled a lil high but the ported intake was matched for a heads an cam car so it had a bigger whole drilled. So I'm hoping that's just a tune issue. Also the throttle body was sticking.
I know I have a different cam gear on my TB then the one I bought from him. So the cables were a little loose and I didn't see any place to adjust my cables. The damn throttle body was sticking open. I tap the gas just a little bit to raise the RPMs to 1500 and they would stay there.
Besides fixing the obvious problems and getting a tune is there any advice from you guys out there? Anything from your LS6 swaps. Anybody have these issues in the past?
Well that's really fast for never having done it, took me a few hours from start to finish. Did you put a different TB on yours? That's the reason my ***** sticking now is from the ported TB. Did you get great results right away with no tune?
I talked to a few people and they said that it's a common problem when pulling a motor or changing an intake to break that sender. I don't even remember breaking it, when I got the intake off it was broke so I'm thinking the buddy I had with me may have done it when I asked him to push from the back he went too far back and didn't know what he was pulling on thinknig it was the intake. Either way, it's a 10 year old piece of plastic that's really brittle.
The good news is I got the oil pressure sender ordered today for 44 bucks and got some hose to fix my PCV. I'm going to put my stock TB back on and see what happens. BTW I was looking for advice.
You'll love the ls6 intake. I picked up 2mph in the 1/4mile with mine.
For the throttle body. Mine was sticking, so I loosened the screws on the blade and kept flipping it open and closed so it would recenter itself and i have not had a problem since. Maybe that will work for you.
So after you fliped it a few times you just retightened the screws? I need to get the car out of my buddys driveway so i'm just gonna put my old one on then do what you said. I'm having the car tuned on tuesday so maybe I'll put it back on then. The guys as G-Force told me just to leave my stock one on there for the tune because they have so many problems with the ported throttle bodies. I may just buy a brand name TB.
I'm wanting to do every single bolt on possible before I pay the $500 to get it tuned(minus H/C). So far I got..MSD wires, NGK plugs, Pacesetter LTs w/ORY (ordered a cutout today), SLOWMaster cat back, LS6 Intake, Free air mod (Still looking for a cheap LID) my lid has the baffles removed (home made) Ordered the 160 degree thermostate. Bought a SLP 25% underdrive pulley to put on before the tune. I think I'm just lacking the lid/smooth bellows and TB. I also want to get SFCs, panhard bars, rear sway, and other suspension mods.
Ya, plans sound good.
I have pretty much full bolt ons and have not gotten my car tuned yet either. IMO there is no point in getting a tune right now if your going to be installing a cam and/or heads within a reasonable amount of time. Better to just wait and save the extra cash.
Let me know if that straightens out your throttle body.
Well I decided to just throw my stock TB on the LS6 IM. It fixed the problem obviously so I'll be tinkering with the ported TB and possibly putting it back on there. So tomarrow I'm gonna get to take the whole damn thing back off and replace the oil pressure sender. While I'm in there I'm going to be replacing the pcv hoseing with some hose from the auto parts store.
One question I have is how to take off that fitting that holds the sensor, brake booster hose and AC hose at the back of the manifold. The little clip that holds that manifold pressure sensor is broke off and I have it held in with RTV right now. The one on my old manifold is good though. Sucks I didn't realise it until after I started taking the old manifold off. Seems to be holding up well so far.
With the stock TB back on and the car running good I got to actually feel the power that the IM added. Nice, not like OMG nice, but nice none the less. Thanx again for everyones help.
Next week I'm putting on the under drive pulley, anyone have a suggestion on what belts to use with the SLP 25% ? I saw the ones that weren't V rib, anybody have luck with those?
