Anyone with a cutout even make more power closed?
Just curious, I had cutouts put on when the exhaust was done up for the ls1 swap because the car has a 2.25" dual system and I wanted to be sure the exhaust wasn't holding me back...but it actually seems to run better with them capped. Could it just be feeling increased torque? Or could the cutouts actually be cause changes in the pcm what would cause a power loss?
I do know for some reason only 1 o2 sensor hasn't been tuned out, and with the cutouts open my mpg goes to absolute ****. Seems to run fine but almost like it kinda "bogs" a little in mid range rpm versus having them closed.
The cutouts are between 1.5' and 2' behind the collectors of the longtubes btw.
sounds exactly like what I just went through. my car got tuned with a VERY MILD pinhole exhaust leak downstream of the O2s and caused it to be tuned incorrectly. This resulted in shitty gas milage and complete loss of power in the bottom end. This is because every pulse of the exhaust actually sucks air in that pinhole causing the O2s to read clean air, resulting in false lean condtion. This, in turn, caused the pcm to richen up the A/F and make it act like a turd. Got it sealed up and retuned. BAM, the car with open exhaust runs now with more power than it does closed like it should. Sealed exhaust is key for a tune. After the tune, open her up like she should be!
~Austin
~Austin
~Austin
~Austin
I did gain a few ft/lbs with them open, but the BEST thing is its great for cookin' fart can rice.
wonder if that might be where some more of my power is hiding...on the dyno I had them open and it took me a good several tries backing onto the stupid rollers (i suck at backing into small spaces)
I'm just searching everywhere I can because the car only put down 325hp/340tq (granted I was only getting 92% throttle at the time) so I've kinda been scratching my head but I keep noticing it feels slower with the exhaust open
if that turns out to be the case then so much for trying to bypass my small exhaust haha
I gain more power everywhere with my cutout open. It's hard to compare them on the dyno. My a/f with the cutout open was 13.2 up top, capped the cutout and it went up to 13.7 but still didn't make more power than with the cutout open. Plus, I like it loud.
I've run my car at the track many times with the cut-out open on some runs, and closed on others. I could not tell any difference in times or mph with it opened or closed. I don't think it sounds any better with it open except at idle it sounds good. Cars with cutouts don't sound good at WOT imo. Duals with bullets sound much better.
I have true duals without cutouts. I wish I had dual electric cutouts tho. I would sacrifice 10 hp for how loud cutouts are. My exhaust is pretty loud so I'm leaving it alone.
Weird tho, I would think with the cutout open you would gain hp.
I always thougth mine felt stronger (SOTP) with it closed. I did however notice a significant time improvement with it open. It felt like I just lost the low end grunt with it open. Either way the time slips show me to be wrong.
open ex: just normal driving say rolling at 25 and punch feels stronger capped, but if i hammer it on the highway at 60 or 70 much quicker open!
You'll get better TQ in the bottom end of the powerband with it closed, however, the engine will be able to breathe better on the top end with it open. Basically you will feel a better take off with it closed, but with it open you'll gain a couple horses when you're near or at WOT
