what is this and what does it do?
Old Jan 2, 2009 | 04:03 PM
awd-rwd racer's Avatar
Default what is this and what does it do?
the spot with the arrow is the brass nipple on the tb. and the circled part i believe is the char canister relief. but i do not have the circled part on my engine. so what do i connect the nipple to?
Old Jan 2, 2009 | 04:09 PM
DaveX's Avatar
I believe that is a vent for the fuel tank. There is a tube that connects the 2 places you are asking about.
Old Jan 2, 2009 | 06:04 PM
nemss1's Avatar
EVAP purge solenoid. took all that emissions crap off on mine
Old Jan 2, 2009 | 09:35 PM
bczee's Avatar
+1 on the EVAP.. the port on the side of the Intake will feed into the EVAP Valve and Solenoid. There should be a port on the back side that would connect to the Vent line that run from the Fuel tank
You can remove it without to much problem by just pluging the port...
You should then flash out the function out of the PCM.
But one think you should consider.. that the Tank needs to vent and purge air/vapors out of the tank... and that is one of the function of the EVAP System. If you don't vent the take one way or another.. you will create vacuum in the tank and may cause fuel feeding problems. You can just vent the tank, run the vent lines to a Charcoal Canister or just use the EVAP. If you just vent into the air and you park inside, you might start getting fuel vapor around the car inside... not a good thing.
What I did was keep my existing Charcoal Canister and used the port on the intake to use as the Charcoal Canister Vacuum source.
Old Jan 2, 2009 | 10:05 PM
nemss1's Avatar
i deleted my whole EVAP and charcoal canister. have a filter to vent the tank
Old Jan 2, 2009 | 10:47 PM
1badrz28's Avatar
Have any pics of your filter?
Old Jan 2, 2009 | 11:10 PM
nemss1's Avatar
i can try to get some in the morning. its just a small k&n breather. 3/8 size neck i think.
there was a line from the top of the gas tank that lead to the charcoal box. i removed all EVAP and charcoal box and squeezed the breather onto the hose that lead to the charcoal box
Old Jan 2, 2009 | 11:12 PM
nemss1's Avatar
and i havent noticed any gas smell probs unless im just immune to it
Old Jan 2, 2009 | 11:14 PM
1badrz28's Avatar
Wouldn't a vented gas cap take care of the venting or maybe they don't make them for this model and year.
Old Jan 3, 2009 | 12:09 AM
nemss1's Avatar
ya a vented cap would take care of the venting. i just didnt really look for one
Old Jan 3, 2009 | 01:27 AM
the_merv's Avatar
I just made the EVAP line a Vent, cut it short and stuffed it in the Fender. The Tank also has a normal Vent as well.
