I pulled the exhaust off the Y pipe. Then I unbolt the panhard rod, shocks, and sway bar from the rear. Leave the drive shaft, torque arm and lower control arms on the rear. Then slowly let the rear swing down out of the way, watch the E brake cables and brake lines, when they are starting to get tight I will stop and raise the rear just a bit to take the stress off the brake lines, and cables. Open the gas fill door and take out the 2 or 3 screws holding the black plastic around the fill neck. Then get in to the wheel well... between the tire and rear bumper. There is 1 bolt holding the fill neck to the car, remove it. Also I will drive my car around untill the check gauge light comes on so the tank is as light as possibe. Next remove the 2 straps holding the tank in the car, let it down on the axle, remove the fuel lines and electric plugs and the the tank can come out on the floor.
