TPIS 90mm LS6 Intake Pics
I have posted my test results when comparing an LS6 (very similar to the TPIS version) to a ported aluminum Weiand. The Weiand had an 87mm opening & the LS6 an 87mm opening. Both had 85mm throttle bodies. The amount of air moving through the MAF was recorded. Don't remember the exact numbers, but the LS6 moved 8% more air mid-rpms & then 4% @ high-rpms all the way until airflow was limited by valvetrain speed, just over 6,300 RPM. Mods in signature. Had the Weiand been stock, the numbers would have been even greater. The 90mm LS6 mod is for real.
much this intake works. When i ask people what they gains in the 1/4 with a FAST i dont
get an answer...lol. But i expect the TPIS would be good for 15 rwhp without loosing any
low end. And it only cost $350 if you send in your intake and wait to get it back. Much better deal than FAST for same or better gains.
I am having big time issues getting this bitch tuned again. My IAC counts start high when cold and end up at 2-4 after warmed up. Playing with the TPS and throttle blade do nothing. I even went back to my stock tune with no change. Everything points to a nice vacuum leak but after removing and replacing the PCV hoses and my catch can and even using propane gas at all manifold joints, no leaks were found. I said screw it and will be taking the intake off again to do some vacuum test on it off of the engine. Also, I ordered a Polluter cam just to make myself feel better about the whole ordeal.
Re-scale the MAF table. Also, have a look @ ECT & IAT spark.
To properly re-scale the MAF @ idle, the STFT's should be within 0 to -3% @ idle, then follow the % increased during idle through the rest of the table. The "desired airflow" settings need to increased because the airflow through the IAC has increseasd per count, as a result of the intake manifold change. May sound strange because the count value hasn't changed, but is the case. Even a less restrictive air filter can effect matching the idle "desired airflow" to actual.
Once the MAF table is re-scaled as noted, your engine will achieve the maximum benefit of the intake modification.
Could be. As long as changing the desired airflow table doesn't make it idle differently, a vacuum leak seems possible. The "desired airflow table" isn't counts, it defines the airflow expected @ varying ECT (engine cooling temperature) while in gear & then while in park/neutral. It's related to coolant temperature, not Idle air control position. Do you have EFI Live?
Do you have breathers on the valve covers & the PCV hooked up to the intake?
With the car @ operating temperature & sitting still, is where you want to confirm the STFT's. If this is what you mean by "for the little bit of driving, then I'd say you're MAF table is close. Maybe decrease the whole table by 2% ish. The MAF table is what will allow the benefit of the 90mm inlet change. Has less effect on idle, but could have been a contributor. It can now be ruled out as part of an idling issue.
