Buying new intake.
Old Feb 24, 2009 | 11:34 AM
ScreamingEagle's Avatar
Default Buying new intake.
I have the chance to buy a intake off of a 2002 camaro. Is this the LS6 one I need for mine, is not having a egr a problem? Also, what throttle body would I need for it?
I figured this would compliment my exhaust nicely and then I could get a tune.
Old Feb 24, 2009 | 12:14 PM
zacht's Avatar
not having egr, depends if you have to take a sniffer test. still might pass with converters on the car. yeah it "should" be a LS6 intake. look up the part number on it to be sure. there are LS6 intakes with egr out there if you want to keep the egr, or tap that manifold for egr.
stock throttle body will work.
just check the part numbers. ill help you out. ill post up in a minute.
Old Feb 24, 2009 | 12:16 PM
Thanks. Would it be worth it to change to TB/MAF on it or not? Just a bolt in replacment right?
zacht's Avatar
k man, found some part numbers for ya.
LS1 intake manifold, with EGR (98-00 F-body) = 12561269 (formerly 12560688)
LS1 intake manifold, no EGR (from 97-00 Corvette) = 88894095 (formerly 12557846, 12556333)
LS6 intake manifold (01-02 F-body) = 88894339 (formerly 88890524, 88890523, 12561184)
LS6 intake manifold (from Corvette Z06) = ? (formerly 12573572)
Old Feb 24, 2009 | 12:19 PM
zacht's Avatar
hmm, for now i would say no. i think the LS6 and LS1 have the same size throttle body.
one thing that would help is porting your throttle body.
>>>>>>>>>heres a link to help you<<<<<<<<(if your a diy kinda guy)
http://www.ewurl.com/post/DIY-Portin...ttle-Body.aspx
and the MAF sensor isnt restrictive, unless over like 500 horsepower it would help. also do you have a lid/FIPK and smooth bellows too?
Old Feb 24, 2009 | 12:28 PM
Yep, got the lid and smooth bellows.
Old Feb 26, 2009 | 12:58 PM
moosezloose's Avatar
LS1 and LS6 is the same size throttle body. The LS6 is also a great choice and definately the best bang for the buck.
Old Feb 26, 2009 | 01:18 PM
mandreake's Avatar
how work ls6 intake and 80 0r 85 mm tb
Old Feb 26, 2009 | 02:03 PM
twitchtwice's Avatar
its not worth it, port the stock tb with one of the sponsors here for 60 bucks and be done with it.
