post your PCV problem solutions
Old Oct 14, 2003 | 09:52 AM
Vents's Avatar
Default post your PCV problem solutions
i've got an LS6 valley cover, and a draw through from the valley cover to the TB. still pulling in oil. anyone have any GOOD cheap alternitaves to fix this oil consumption problem? just looking for other's insight/ solutions.
Old Oct 14, 2003 | 01:58 PM
LOnSLO's Avatar
Default Re: post your PCV problem solutions
Thought about trying a vacuum pump? I wasted my money too, on the LS6 cover. I suck in more oil now than ever. I'll be totally deleting the PCV system with the new motor, and run a vacuum pump.
Old Oct 14, 2003 | 02:20 PM
Cal's Avatar
Cal
Well the LS6 cover worked for me, no oil in the Sears air separator; but hmmm. . . still consuming oil-must be getting by the rings. About half as much as before, though.
Old Oct 14, 2003 | 06:07 PM
theblur98ss's Avatar
I just took off my whole PCV system. I had a seperator in the main line but it was sucking it from the valve covers. I just capped everything off and I'm running dual breathers. Not many miles on the setup yet so we'll see how it goes.
Old Oct 14, 2003 | 08:17 PM
z2beat's Avatar
I installed the 6L truck pcv vlv (Ask dealer about service bulletin, no ball, just a small hole). Also made a catch can out of pvc pipe. Looks stock & seems to work but hasn't been installed long enough to see how good.
Old Oct 14, 2003 | 09:20 PM
SmaknaSS's Avatar
LS6 valley cover worked for me. LS6 PCV valley cover + catchcan made from PVC pipe works really well for me. Just about no oil is getting in to my intake now.
Old Oct 15, 2003 | 09:42 AM
4thGENRETARD's Avatar
The breather on the driver side will soon get saturated and spill oil all over the back of your engine. route a pcv line fom that side to the other one on the passenger side into a catch can and you'll reduce oil in intake dramatically..
Ask COLONEL he can verify that.
Old Oct 15, 2003 | 01:58 PM
FEAR THE LS1's Avatar
I had posted pics of my PCV setup a few months back.
I used steel braided hose from each valve cover and ran it through an air/oil seperator then vented it back into the stock pcv valve and into the intake manifold like the stock pcv system.
I empty the Oil/Air catcher every couple weeks, and it usually has about 4-5 ounces of oily crap in it. Especially when racing, at WOT it accumulates alot more.
I took the pics offline, I will reupload then tonite.
Old Oct 15, 2003 | 02:02 PM
Fireball's Avatar
I use a vertical PCV setup pulling thru the LS6 valley cover. Don't use a drop of oil now...
Old Oct 15, 2003 | 02:31 PM
horist's Avatar
i've gotta ls6 PCV setup also (replaced lifter valley cover) and it wouls moke like a son of a bitch after I finished my build up (sucking oil)
I then constructed a cheap catch can outta some clear vinyl hose, some barb fittings, and a sears air/water seperator.... seems to catch most of the oil (only smoke a little now when I start to accelerate)
Old Oct 15, 2003 | 02:43 PM
Vents's Avatar
i think im gonna try the vertical PCV catch can idea, since i've relocated the battery now. we'll see how that goes.. thanks guys
