initial timing on LS1?
Old Feb 27, 2009 | 05:37 PM
kibZ28's Avatar
Default initial timing on LS1?
i was wondering what the initail timing on an ls1 is so i have a baseline to set my car up??
Old Feb 27, 2009 | 08:55 PM
S10xGN's Avatar
And just how would you do that? All timing functions are handled by the PCM and the sensors are all fixed (no adjustability).
Russ
Old Feb 27, 2009 | 09:42 PM
vsocks1's Avatar
Russ
Isn't that what tuning software is for?
Old Feb 27, 2009 | 10:11 PM
wht01ws6ta's Avatar
What are you using to tune? You can download stock tunes from a tune repository to see what a stock table looks like. But there are calculations done so the actual timing will be different.
Old Feb 28, 2009 | 08:51 AM
Full-Force's Avatar
Maybe he is running a car/distributor setup.
If so I would start with 8-10. On SBC's I used to run about 12-13* for a high performance app.
Old Feb 28, 2009 | 09:18 AM
kibZ28's Avatar
no with the diablo sport because u can set it i knwo the comp is going to make up for it anyway but i need a setting number??
Old Feb 28, 2009 | 10:28 AM
vsocks1's Avatar
I would try 24 degrees maybe?
Old Aug 3, 2009 | 04:35 PM
Ls1Mx-5's Avatar
I've been hearing 28 is the magic number
