Header install Grinding the tabs on block?
Old Mar 2, 2009 | 04:46 PM
1999FirehawkLS1's Avatar
Default Header install Grinding the tabs on block?
I am getting ready to install headers on my TA and as much trouble as those tabs on the side of the block gave me getting my macs out i was thinking of grinding the tabs on both sides of the block off..........anyone done this? Is there anything i need to worry about before i do this?
Old Mar 3, 2009 | 12:10 AM
tording99Z28's Avatar
No, those tabs are a PITA for most people and from what I have seen will cause no issues if you grind them down. I installed Pacesetter LT headers on my Z28 and those tabs did not give me a bit of trouble, the headers went right in without a hitch. If you are installing Pacesetters might be worth it to try puting them in before you grind them off. I did also do prothane motor mounts at the same time though so this could be why I had no issues with the tabs being in the way. Good Luck!
Old Mar 3, 2009 | 12:13 AM
jetlag's Avatar
I've installed Pacesetters on 3 Camaros, and every time I had to grind the tab off on the driver side.
A sawzall takes care of it quick
Old Mar 3, 2009 | 12:19 AM
I guess I got lucky! Yay me!!
Old Mar 3, 2009 | 07:44 AM
teke184's Avatar
i did it out of precaution when i did my LT install.
with a handheld hacksaw it took all of 3 mins.
why not...nothing to be lost by doing it...
Old Mar 3, 2009 | 01:47 PM
CaliboyTA's Avatar
i have pacesetters and i didnt grind off the tabs, then again i had my heads off so maneuvering the headers were alot easier
Old Mar 3, 2009 | 04:51 PM
Thx guys ya i think i might do it just so i dont mess up the finish on Brand new LTs im running 1 7/8 so its going to be even tighter than the pacesetter going in
Old Mar 6, 2009 | 09:41 PM
john shea's Avatar
I cut mine off with a sawzall.
