PICS Bassani Tru Dual X PLUS Moroso Spiral Flows
It hangs about as low as everybody elses. They are ran from the factory cats. I didn't put the brace that is pass the transmission back on. I might try to put it back on and wrap it in something rubber because this setup hangs lower than stock. Instead of the Bassani muffler and slash tips that come with it, I had Moroso Spiral flows custom fit to it matched to my center mount. It's not the best bending job going to the center mount but it's ok. I did not like the way the Bassani muffler sounded at all. It's so raspy. This is a little louder than stock at idle and has a deep bassy tone when driving normal. WOT sounds amazing. No backfire and no rasp, zero drone on the highway and it feels SO MUCH faster. I can't believe how much faster it feels. This is the best exhaust upgrade I've done on any of my vehicles.
I don't have any shots in the air. I will try and get a sound clip tomorrow to post up.
![](http://img23.imageshack.us/img23/8070/1001714.jpg)
![](http://img261.imageshack.us/img261/1262/1001713.jpg)
![](http://img166.imageshack.us/img166/3319/1001711.jpg)
![](http://img261.imageshack.us/img261/9408/1001715.jpg)
![](http://img23.imageshack.us/img23/2546/1001712.jpg)
My Bassani duals don't hang that low before the x-pipe, but there was extra attention paid to really tuck them up.. However, between the X and the axle, yours are tucked up better than mine, but I'm going to try and adjust that next time it's on the lift.
So I put the brace thats right after the transmission back under the car with alot of rubberized coating and sound deadener. It tucked the exhaust up about 1/2" but makes a horrible vibration. I had to take it back off. Once my exhaust got fully settled it started banging the upper panhard bar. I put a notch in the bar so it doesn't hit anymore. I only cut about 1/4" off. The whole exhaust barely moves and it was just touching the bar.
You can put the brace (behind the transmission) back on. Get some thick washers or stack a bunch of thins ones, to create extra space between it and your exhaust.
My Y pipe hangs that low. Hopefully I'll fix that with new motor/trans mounts.
