E-Brake Ajustment
Old Mar 25, 2009 | 08:11 PM
Rileyt's Avatar
Default E-Brake Ajustment
i have a 98 Z28 and i need to ajust the e-brake and didnt see really how to do it from underneath the car? anyone no how too?
Old Mar 25, 2009 | 10:23 PM
Rileyt's Avatar
so no one in here nows how to ajust an e-brake?
Old Mar 25, 2009 | 10:42 PM
GMRL's Avatar
Well, seeing as how your car is 10 years old and depending on the mileage.
I would say that your e-brake shoe is worn out.
To adjust or replace it, remove the caliper and rotor. You will see the e-brake shoe, if its not worn out. You can adjust it by turning the adjusting star to set the preload on the shoe. Im not very good at explaining things, but once you get the rotor off and get a look at the shoe youll see what Im talking about.
Old Mar 26, 2009 | 07:20 AM
vsocks1's Avatar
Yeah, if it is like a vette there is no slot for adjusting like on some older cars. You have to take the rotor off to adjust.
Old Mar 26, 2009 | 08:46 AM
Rileyt's Avatar
and that goes for both sides right rear and left rear?
Old Mar 26, 2009 | 12:17 PM
dansean1's Avatar
If all LS1's are the same. Check the shoes for wear. If they are fine you should see a small spinning adjustment wheel tucked in there. I believe its exposed, not behind the brake assembly. You adjust that til it firms up.
Just go slowly, checking and that should work.
My ebrake handle used to go all the way up and was rather useless. After adjusting both sides because I had to do the brakes, it turned out great.
Old Mar 26, 2009 | 04:19 PM
Black 99 Bird's Avatar
Yes left and right, take the rotors off you will see the adjustment wheel.
Old Mar 26, 2009 | 06:02 PM
bigti99a's Avatar
say the ebrake shoe is worn. will any auto parts store carry a replacement? what would you ask for?
Old Mar 26, 2009 | 06:58 PM
Weezzer's Avatar
Originally Posted by bigti99a
... what would you ask for?
I'd ask for the E brake shoe.
Old Mar 26, 2009 | 07:47 PM
bigti99a's Avatar
thanks. i wish i would have replaced them when i put on my slotted rotors.
Old Mar 27, 2009 | 09:47 AM
Rileyt's Avatar
hey big hpw do you like your d&s rotors i have been debating them for some time now?
OP my e brake handle still comes up a ways but it is at least tight now. the shoes looked good but when i ajusted them out i went to far then couldnt get the rotor back on so it better but not as tight as i would like.
Old Mar 27, 2009 | 10:06 AM
bigti99a's Avatar
i just have slotted rotors, i was afraid of cracking on the drilled ones. and for the street the slotted with the hawk hps pads are good for me.
Old Mar 27, 2009 | 11:16 AM
dlandsvZ28's Avatar
It would be hard to imagine the shoes would be worn out or would ever wear out unless you constantly leave the e brake on which would wear the shoes down.
Changing rotors is what changes the e brake shoe to rotor clearance most times. For example: I never had to adjust the e brake when replacing the stock rear rotors to Autozone blanks but when switching from the Autozone blanks to the EBC rotors required a big adjustment.
Old Mar 27, 2009 | 07:43 PM
Rileyt's Avatar
ok well they are the stock rotors and i just didnt get them ajusted where i really wanted it but it is tighter than before i was wanting the handle to tight about a 1/4 of the way not 3/4 but i couldnt cause the rotors wouldnt fit back over the shoes.
Old Mar 27, 2009 | 09:35 PM
bigti99a's Avatar
how high do you have to pull it now?
Old Mar 27, 2009 | 09:39 PM
dlandsvZ28's Avatar
My car is on jack stands - will look tomorrow. Seems I recall that the cable can be adjusted just in front and above the rearend. Don't recall if there is cable adjustment under the console at the e brake handle.
Old Apr 3, 2009 | 01:01 PM
Rileyt's Avatar
well i thought that it was fixed but yesterday i pulled it out of the garage and into my driveway whick is on an incline and the e brake wouldnt even hold it. so i dont know if i went the wrong way with the star ajustment? i turned them out so the little piston in there was spreading the e brake shoe further apart? is that right or even make sense?
Old Apr 3, 2009 | 02:39 PM
dlandsvZ28's Avatar
You adjust same way you adjust drum brakes with shoes. I put mine on jack stands adjusted - pulled the e brake - adjusted -pulled the e brake and so on. I went too far and couldn't even turn the wheels so had to back off.
I orginally thought my e hand brake only went up about 1/4 of the way to hold when parking (memory) since I drive it so little. But just about every picture you see with the e brake on - it's at least 1/2 way up. Mine goes about 1/2 way up now after adjusting and holds but I have an a4 too.
I would assume that if you adjusted until you can just barely turn the wheels but the e brake handle still pulls more than 1/2 to all way without locking up the wheels then you might have cable stretch.
I still haven't had time to look under my car to see where to adjust for cable stretch.
Old Apr 6, 2009 | 04:21 PM
Rileyt's Avatar
ok well i def need some help cause whatever it is that i done made it worse so im thinking about putting it back to see if that would help but it just doesnt make any sense. and that you would think by ajusting that star out would be what needs to be done but didnt work in this case
Old Apr 9, 2009 | 04:36 PM
Rileyt's Avatar
bump!
