Problem after header install
Old Apr 1, 2009 | 04:19 PM
|2ocky's Avatar
Default Problem after header install
I have an 01 z28 that was stock other than a lid an exhaust. I recently put some pacestter longtubes and off road y pipe on it and it runs pretty horrible. I put the headers on a couple months ago but don't drive the car daily, and when I first put them on it ran much better than it does now. I am getting about 10 mpg and getting a lot of bucking throughout the rpms and sometimes if I get on it it wil start backfireing and breaking up. I have had a blinking check engine light on a few occasions as well. I think the problem is that i haven't had the rear o2 sensors tuned out which is causing the car to run like this, but I have seen other people running headers on the stock tune all the time. Any ideas?
Old Apr 1, 2009 | 04:25 PM
massls1guy's Avatar
I would check your plugs & wires. It's easy to crack the porcelain on a plug when installing headers.
Old Apr 1, 2009 | 04:33 PM
1gt2nv's Avatar
The blinking ses light is a missfire. I'd bet your plugs or wires are bad. My turbo gt did this last summer. I'd go wot and the car would break up and missfire very bad. The rear o2's don't really cause the car to run bad. They just read the cats. Good luck.
Old Apr 1, 2009 | 04:56 PM
|2ocky's Avatar
Alright I will look into that, thanks for the replies.
Old Apr 1, 2009 | 06:32 PM
SOMbitch's Avatar
Or burned on O2 wire on the header........Usually DS.
Old Apr 1, 2009 | 07:14 PM
|2ocky's Avatar
So if a front o2 sensor or wire was messed up it would cause problems, but not if it were a rear sensor?
Old Apr 2, 2009 | 05:44 PM
nebur8's Avatar
you can run fine without rear sensors, so it is unlikely the issue is from a rear sensor. I would check plugs and wires first. had a similar issue and it turned out to be a wire wasnt pushed all the way down on two of my plugs.
Old Apr 2, 2009 | 05:50 PM
rice4eatingnotdrivin's Avatar
check and see if any of the plug wires came loose... happend to me on the passenger side the very back cylinder u can barely get to.. thought i had it on all the way and it wiggled its way loose
Old Apr 3, 2009 | 11:42 AM
ds98formula's Avatar
Its blinking like others have said because of a misfire. the reason it blinks is to warn you it will ruin the cataltic converter if not taken care of asap. Check spark like everyone said. Good luck finding it.
