Anyone using QTP dual cutout y-pipe?
I went from stock manifolds with cats and cutout, to this setup, and the SOTP increase is HUGE. I've got the TR 224 on a 114 and it seems to breathe SO much better.
Last night was driving downtown and as I drove in front of a parking garage I set off a car alarm inside the garage.
The QTP cutout openers rock as well. I had the McCord and the QTPs seem to seal a little better.Edit: My car is the one Arctic98Z mentioned
also what kinda switch did u use and where did u put it?
also what kinda switch did u use and where did u put it?The cutouts come individually, and it's easiest if you wire them into each other, so you only have one switch to mess with, when opening the two cutouts. Any double throw momentary switch would work, I still haven't decided which one I'm going to use.
The cutouts don't come on the y-pipe, but attach very easily.
Install advice, get the car pretty high in the air, we used 6 ton jack stands and two 2x4 blocks of wood... but, that was probably higher than needed. Also, remove the steering shaft as it makes the driver side a LOT easier to get in. We also had to remove some oil thingie that sat just above the oil filter, the bolts from it were in the way (and scratching the header on the way up)
All in all, it wasn't hard, we took our time, watched movies and ate pizza, and still didn't take that long, we started at noon, and were done by 9:30... with lots of breaks.... easily able to be done in 6 hours.
One note on the I-pipe, we had to cut a section off to make the Y-pipe mate up, which means you need a good cutting tool. We had a pipe cutter thingie from Auto-zone, but it sucked, so we wound up using a sawzall to cut thru, and it worked like a champ.
If anyone has any questions feel free to call us.
Did you guys quit sending the little add on pipes after the Qtecs? because i didn't get any. Also, what about that hanger on the passenger side, mine doesn't have that?
You guys will also want to take notice that if you have subframes you will have clearence issues with the end of the Qtecs. i have BMR tubulars and had to have my passenger side cut-out re-worked so the Qtech would clear the subframe.
damn that thing is loud
