pacesetter questions....
Old Nov 4, 2003 | 11:55 AM
WS6FirebirdTA00's Avatar
Default pacesetter questions....
ok few questions:
-coating, what kind and is it inside and out?
-clearance, will i lose much ground clearance with these?
-how do they fit in there?
-what about the sound?
-qualitly and how long do they stay lookin good?
-can u get them without emissions provisions?
-mendrel bent headers and pipe right?
-and its a 3" ypipe with 3" collector right?
anyone have pics or sound clips?
Old Nov 4, 2003 | 02:14 PM
Anyone?
Old Nov 4, 2003 | 02:50 PM
also on a bolt on car what kind HP gains should i expect with these?
Old Nov 4, 2003 | 02:54 PM
Cal's Avatar
Cal
Long-tube headers usually yield 20 to 30 hp depending on how modified the engine is already. Stainless steel headers last longer than ceramic coating, but cost a lot more. The ceramic eventually starts coming off. QTP's and FLP's have the best ground clearance, don't know about Pacesetters. Maybe someone else will chime in . . .
Old Nov 4, 2003 | 04:21 PM
samz28's Avatar
i keep hearing the ORY on the pacesetters suck, anyone care to explain why? and if they've done any re-engineering?
Anyone got any strap on heatshields that look like cats lol for sale?
Old Nov 4, 2003 | 04:47 PM
i would like to know why they suck too
Old Nov 4, 2003 | 09:27 PM
Y2KSS's Avatar
I have the Pacesetter LT's and Y-pipe. The Y-pipe sucks because where the driver side tube is welded into the passenger side tube, they did not cut the hole big enough before they welded it up so half the tube is blocked off. I cut mine off, redone it and welded it back up and now it is fine. Hope this explanation helps. However, the coated headers fit and look great. No complaints on them.
Old Nov 25, 2003 | 12:17 PM
ShadowLightCSU's Avatar
Seems nobody wants to answer the inside and out coating question.
Old Nov 25, 2003 | 12:24 PM
im tryin to find that out from texas speed, ill post when i find out. i ordered some they are on the way. special ends at the end of november, i get a free tshirt and 2 free o2 extentions. that and headers and ypipe shiped for 498...couldnt pass that deal up lol
Old Nov 25, 2003 | 12:43 PM
I called and they said it's only on the outside, I bought them as well.
Old Nov 25, 2003 | 12:51 PM
would it really make a difference on the inside? maybe thats why the ones coated on the inside get the 2 extra hp.....not enough to pay the extra couple hundred bucks lol
Old Nov 25, 2003 | 02:00 PM
It's that exhaust gasses are corrosive and can rust from the inside.
Old Nov 25, 2003 | 02:59 PM
foff667's Avatar
LS1TECH Sponsor
because of my pacesetter order b eing screwed up i got one of each coated and uncoated and can say dont get uncoated...even though it may not be on the inside it definitly hasnt started to rust like the uncoated one already has...if you have the extra money id say go with kooks stainless longtubes and a custom ypipe cuz their ypipe isnt all that good. FYI its not that pacesetters coating is any worse than anyone elses...ive seen my fair share of jet hot coatings burn through...yes they have a warranty but see how much you want to take those headers off if need be and possibly have your car not being able to run for a month while they redue yours, not fun. They should last a while but stainless really is the way to go.
lata
Bill
Old Nov 25, 2003 | 03:30 PM
DeepBlueZ's Avatar
ground clearance isnt bad with them....the driver side header does have a little clearnace issue with the K-member on some cars (not all)...nothing 5 minutes and a grinder couldnt fix....also the y-pipe is pretty close and will bang the floorpan on the driver side if it isnt secured properly...
Old Nov 25, 2003 | 03:35 PM
hourang's Avatar
the pacesetter headers are a good set, the headers them self are awesome and fit great. the ypipe is the most painfull part. it is not a great fit, it is really tight and is way too close to the bottom of the car, touches the torque arm and was touching the fuel lines the muffler hanger needs to be removed to move the exhaust back enough to fit the drivers side piece in between the header and i pipe. the pass. side is a pain to connect to the ypipe, it is real tight and goes in on an angle, we had to cut a 1/4in of the pipe to get it to go in there and we had to kick the hell out of it even then. the ypipe will need to be bent down or dipped where the fuel lines and torque arm are, they hit real bad. other than that, their an awesome set for the price
Old Dec 3, 2003 | 10:11 PM
Danny2tek's Avatar
so you guys recommend having a shop do a y-pipe?
Old Dec 3, 2003 | 10:14 PM
ill let u know after sunday lol im gonna make a post for the install with lots of pics and sound clips
Old Dec 4, 2003 | 01:14 AM
SSEUL8R's Avatar
I just got my pacesetters in yesterday from Trevor at TSP. Atleast that's whose name is on the box. They look really really good, I haven't put them on my car yet, but if they sound and fit as good as they look, then I will be very happy.
Old Dec 4, 2003 | 09:01 AM
v8maro's Avatar
Nah, I used the pacesetter ORP, it banged a little, but nothing an exhaust shop couldnt fix.
-Steve
Old Dec 4, 2003 | 09:16 AM
ZigZagZ's Avatar
Good luck with your install!
