Whats up with this, coolant leaking...
I was thinking maybe a blown head gasket but there would probably be more than just a coolant leak. Only thing I've done to the system is the TB bypass, that is not leaking, nor the radiator, thermostat, or any hoses around there. Any coolant hose I could find I checked, nothing. There is also no coolant running down the face of the block. Checks the plug for the water temp gauge sensor and nothing as well. It has to be coming from some place I can't see. Anyone know what it could be, or what I could check?
Thanks a lot!!!
-Sly
You would be supprised where the fans will blow coolant........, Go pick up a pressure tester and pressure test the cooling system youll find the leak
