Bauer TB picks up 11 RWHP on the dyno(Stock car)...
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
Yep, that's right...
Dyno'd my g-friend's car this weekend and decided to swap my TB on there for ***** and giggles. Before #'s were 301 rwhp(Stock A4), and 312 rwhp with just the swap of a TB! This car has no other mods. No lid, no nothing. With more mods, the car would have definately picked up more with the additional air flow.
Bret does awesome work.....
josh
![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
josh
I was thinking a ported TB should be worth more than 6 hp. I just bored mine out with my lathe and was shocked at how big that bump is in front of the butterfly. Porting by hand it isn't as obvious how much metal you are removing, plus you may not remove as much since you can't tell what you are doing as easy. Removing half the shaft should gain quite a bit as well.
Yeah Bret does very good work. I got my throttle body a couple of months ago, when i put it on and took it out it was not idleing right and there was definately a problem
. I emailed Bret and with no questions asked he told me to send it back and he would take care of it. Sure enough he welded up the idle hole and sent it back to me, it is working perfectly now and definately there is better throttle response
. Thanks for all your help Bret.
Scott
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Scott
![The Patriot !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_patriot.gif)
Originally Posted by 01ws6transam
hmm.. this sounds like a nice mod. is there any tuning issues or anything with a stock car or can i just bolt it on and ill be good to go? if thats the case i mgiht have to pick one up
Josh
Jason, depending on the amount of work your current TB has, i'd say 5-8 rwhp if you did a decent job. However if it's just a clean up, it probably didn't do much and you should see an easy 8-10+ depending. It's really hard to say without seeing the TB, and/or knowing dyno results of what your home porting did your for.
However I can guarantee Bret's are far more worked through than even the most home ported TB, so I think it's safe to say you'll gain power no matter what.
josh
josh
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Originally Posted by 10secondZ
How long does it usually take to get a TB from him?...and does any one have his phone #? thank's,
Carter
Carter
Originally Posted by jaberwaki
how much can a cammed car expect to gain from this?
Good to see a back to back on the dyno with this. I've just done all the work at the drag strip. I've seen guys do the same thing at the track and bolt on 2mph, which makes sense when you see it's a 11rwhp gain.
As for Home Ported vs A Bauer TB. Basically this started out as a home porting and has been progressively ironed out over time. There are so many little things that I look at in the porting and the work now that it does take a good amount of time to do and unfortuneately would take me even longer to teach someone how to do.
We strive to make high quality parts that work. Period. No fluff, no B.S., no
![Leghump](https://ls1tech.com/forums/images/smilies/LS1Tech/leghump.gif)
I'm working on some TB stuff for the new FAST intakes, to bring this all up a notch. Maybe some cylinder heads and camshafts (which I already have) in the future too, but you never know.
Josh thanks for the post. You must be tring to get a free one out of me. ;-) Seriously guys, Josh is just a customer like any of the guys on here, the only one who's gotten a freebie is my father because his car is the R&D C5.
Bret
Originally Posted by samz28
how much dyno hp of a modded (full bolton/cam) car with ls1edit tuning?
did air fuel ratio's change due to the TB?
Don't know, as i've said i've never dynoed the TB. I've just tried it at the track.
The A/F ratio has the possibility of changing due to the fact that the motor is getting more air, but the MAF should account for that.
Bret
