what to use to install headers
Old Aug 1, 2009 | 11:26 AM
spanky1's Avatar
Default what to use to install headers
i got some used MAC mid length headers and was wondering what i need to do to install them. do i need new gaskets and bolts? thanks
Old Aug 1, 2009 | 12:26 PM
MjMaro's Avatar
Here is someone that asked the same question with their LT install. It's virtual the same although I'm not sure if you would need o2 sensor extensions or not, someone will chime in I'm sure.
https://ls1tech.com/forums/generatio...se-needed.html
Old Aug 1, 2009 | 12:29 PM
joesscamaro252's Avatar
Yes you'll need new gaskets, and if you break a bolt, you'll need some new bolts. I'm not too sure on the O2 extensions though...my guess would be no...but I may be wrong. Someone with more knowledge...?
Old Aug 2, 2009 | 09:17 PM
Siciliano15's Avatar
dont need 02 extensions. i just installed my macs
Old Aug 2, 2009 | 09:53 PM
jetlag's Avatar
Well, the first thing you need to do is sell the Mac mids and get long tubes....
haha, j/k
I always reuse gaskets and bolts. My friends stock manifold gaskets were fine at 115k miles...
Old Aug 2, 2009 | 10:08 PM
Monkey_fuerte's Avatar
Put in some new plugs and wires while you're at it.
Old Aug 3, 2009 | 09:40 AM
RedRallyeZ's Avatar
yes, do that. its the last time youll have easy access to the plugs unless you swap to LT's
Old Aug 3, 2009 | 01:27 PM
crossroads's Avatar
I did motor mounts while i had it apart, but you could add to the list for days to justify moddin the car more
BTW I used percy's gaskets FWIW
Old Aug 9, 2009 | 09:31 AM
Notmyvette's Avatar
Where can you get new bolts locally? besides the stealership
Like Advance auto or autozone or something?
I need some today/tomorrow
Old Aug 9, 2009 | 01:37 PM
rice8er's Avatar
haha, j/k
just like he said sell the mids & put long tubes on
Old Aug 17, 2009 | 02:12 PM
spanky1's Avatar
well i would but the motor is in a 96 f-150!!! and the midlength fit the best being that the motor is mid mount and when i took the manifolds off the gaskets looked good so i just reused them thanks!!!!!
