P0327 and a LOUD KNOCK
Well I was sspraying and had to break HARD AS **** which stall the motor then start her back up drive a half mile and i heard this wierd noise and well sure enough it gets louder in a split second everytime i give it gas I get the ******* LOUD as knock I didnt go over 3000 RPMs after hearing the knock (3800 stall) so I need part numbers for the wiring harnesses as I plan to redo everything, guess while the car is down i'll do the MAF sensor also.
/pissy rant/
ANY HELPWOULD BE AWESOME
/pissy rant/
Not long at all. Itll only take a little for it to completely destroy the motor and then youll really have to buy a whole brand new one. Now, you can probably get away with just a little machine work on it or even just rebuilding it if you havent spun any bearings.
PARK IT!!!i broke a rod but when mine broke it was loud..and mine went though the block had to buy a new block and every thing so...stop driving it till you can figure it out could be something small....pushrod..anything
