power sterring deletion question's
Old Sep 20, 2009 | 05:08 AM
biggb's Avatar
Default power sterring deletion question's
please bare with me here as im a noob with ls1's. i have been a mustang guy since i got into this game..
has anyone deleted the power steering by simply looping the lines and keeping the factory rack. we have done this with the fox body's with good success .. this is not a daily driven car and i am well aware of the difficulty at idle turning the wheel, but with the skinnies on the front i think it would be fine, so i am asking from a safety/cheap standpoint here, i have read about people doing the shortbelt mod, but has anyone actually gone further and just kept it that way.. thanks
Old Sep 20, 2009 | 05:09 AM
biggb's Avatar
this is not a perm. fix either just till i get to doing a k member/manual rack setup within the next 6-8 months
Old Sep 20, 2009 | 08:12 AM
01ssreda4's Avatar
I would think it would be fine.
Old Sep 20, 2009 | 09:10 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Mine is looped at the rack. I cut the hard lines down by the rack and connected them with a piece of hose. Been like that for well over a year now and no issues
Old Sep 20, 2009 | 12:50 PM
nemss1's Avatar
Just put plugs over the nipples on mine
Old Sep 20, 2009 | 02:07 PM
biggb's Avatar
anyone have a belt length and a routing diagram link.. thanks
Old Sep 20, 2009 | 03:16 PM
Z28/2002's Avatar
I've got a 51.5" belt on my car. It's turning a Katech tensioner, water pump, alternator, and a Powerbond UD pulley
Old Sep 20, 2009 | 03:38 PM
nemss1's Avatar
52.5 here. Over tensioner, under waterpump, around alternator and crank, then back around tensioner
Old Sep 20, 2009 | 05:06 PM
biggb's Avatar
did you do away with the alt tensioner? and have you had any belt throwing issues, near 6700 rpm
Old Sep 20, 2009 | 06:10 PM
nemss1's Avatar
Yes did away with the alt tensioner. No belt throwing issues
Old Sep 20, 2009 | 06:33 PM
Z28/2002's Avatar
Exact same here just a shorter belt. I haven't had an issue with throwing a belt either and my car has been beyond 8K RPM twice(no rev limiter at the time), I change gears in my TH350 at 7000 .
Old Apr 23, 2011 | 10:08 AM
MYSTIC-1SC's Avatar
Bump for an old thread. Anyone wanna post some pics up of this for me.
Old Apr 23, 2011 | 11:11 AM
Z28/2002's Avatar
I don't have any good ones but these are some old ones of my old motor setups
Old Apr 25, 2011 | 11:24 PM
fastsspr's Avatar
So we can make our factories rack and pinions to manual units?
How many of you use the car in the street.
I want to know if it can hold long term of use that way.
Old Apr 26, 2011 | 12:43 PM
Z28/2002's Avatar
I cut the factory metal lines on my rack and looped them. It's been on the street like that since 2008 and I have yet to have an issue. But my car really doesn't see a lot of street miles either
Old Apr 26, 2011 | 01:15 PM
Dirty Vegas's Avatar
My rack is looped as well. No issues, and I have stock size wheels and tires on the front. Make sure you keep the fronts aired up!!!
Old Sep 24, 2020 | 12:57 AM
fastsspr's Avatar
Question
You have any picture by chance where you cut the metal lines? What you did where pressure hose and return hose goes?
Thanks
Old Sep 24, 2020 | 11:07 AM
Thanks
He hasn't been here for 4 years
Old Oct 7, 2020 | 07:19 PM
imma_stocker's Avatar
Thanks
Google "fbody looped power steering" and go find images that make sense. Basically "loop" the upper fittings like a power steering pump bypass. This way the hoses just push fluid from one side of the rack bladder to the other in a closed circuit. Very little psi to worry about but be sure it is sealed or your tires will find hydraulic fluid. Don't be THAT guy that dumps fluid on the track and hits the wall.
