Installed Water Temp Gauge
I have a 160 t-stat in the car and while crusing lastnight on the highway (it was about 63* outside) my new water temp gauge was reading about 140*. The highest I saw it go was 160* sitting.
Now you are prolly thinking that is pretty cold, well again last night cruisng on the hwy, at around 75 mph the outside air temp was 63* and I have my low fan to turn on at 190*. I have a switch panel where I can controll both my low fans and hi fans. Or when the PCM turns them on, I can see what fan is being used b/c i have LEDs to tell me if the low fan is on or the hi fan is on. So if it is going off of the stock temp, my low fan is A L W A Y S running, which it is b/c my led fro low fan is always lit. I know they turn on and go off what the PCM is telling the stock water temp sensor. And if my car is always reading 210* it makes sense that fan #1 is A L W A Y S running..
So does that seem right, that my car was running that cool?
For me in similar conditions, I get up to around 175* idling and 190* driving (says HP Tuners). Perhaps the sender or the gauge isn`t calibrated properly.
So I started the car and watched the water temp gauge. Now a little background. I have my low fan set to turn on at 190*, goes off at 180* I know when it turns on and off b/c i have LEDs for both low fans and hi fans
Ok so my car was idling and I was watching the water temp gauge. When my LED lit up for the low fan (190*) my water temp gauge said 155*
My gauge is off 35* So now do I need to send my gauge back to the company to get it recalibratetd?
I am kinda pissed now
My water temp is in the back of the passanger head. The stock temp sensor is in the front of the driver head
Here is a pic of the autometer adapter and the sender I am using. I think there is enough tip showing to get a good reading. It is not grounded poorly i know that, and yes i used teflon tape on the pipe threads.
Wouldn't the front of the head (stock gauge) be cooler (fans running) vs. the back of the head (aftermarket water temp gauge) be hotter (no circulating air)?
