pcv question
Old Sep 25, 2009 | 01:12 AM
FL Junkie's Avatar
Default pcv question
i have never used a catch can system. i deleted my pcv system a long time ago. i want to run a catch can now. whats the best way to set this up? i can just run some tubing and get a catch can like this one....http://cgi.ebay.com/ebaymotors/UNIVE...Q5fAccessories
but dont i still need to get a pcv valve to put in this setup?
Old Sep 25, 2009 | 07:18 AM
teke184's Avatar
most of the catchcans on ebay are not very effective. they don't do a good job of pulling the vapor out.
i would check out the cans the RevXtreme makes or the one from Mike Norris.
the RevX comes with a built in PCV...so all you do is run some tubing and mount the can.
Old Sep 25, 2009 | 07:24 AM
cody161's Avatar
there are a couple companies that make really good catch cans. here are the two of them that seem to do really well.
http://www.saikoumichi.com/OCC_explanation.htm
http://www.mikenorrismotorsports.com...atch_Cans.html
Old Sep 25, 2009 | 09:43 AM
MadIceV8's Avatar
Customizing Director
RevXtreme has a really nice can. I just purchased one and am quite happy so far.
View this thread for diagrams. https://ls1tech.com/forums/generatio...outing-ok.html
Old Sep 25, 2009 | 11:11 AM
405HP_Z06's Avatar
RevX or Saikou Michi are the most effective cans currently on the market. Here's another interesting read: https://ls1tech.com/forums/generatio...ls2-427-a.html
Post up if you have further questions.
Old Sep 25, 2009 | 03:12 PM
FL Junkie's Avatar
thanks for that info. but i dont have a pcv system like what is pictured with all those catch cans. is there a way to do it without one or will i need one?
Old Sep 25, 2009 | 03:44 PM
405HP_Z06's Avatar
Are you trying to reinstall your PCV system like stock or install a catch can?
Old Sep 25, 2009 | 04:19 PM
FL Junkie's Avatar
no i deleted my whole pcv system like 2 years ago. i gave the pcv away. im running the small breathers on the valve covers and plugged everything else. the only problem is it spits oil vapor all over the valve covers and i lose oil eventually. it lets condensation inside also.
so now i want to go to a catch can setup. i just dont know much about them.
Old Sep 25, 2009 | 04:32 PM
405HP_Z06's Avatar
Okay, I'm trying to figure out what makes your PCV system different from other LSx engines. What information are you looking for that's not in the threads referenced above?
Old Sep 25, 2009 | 04:52 PM
LS6427's Avatar
You have oil spitting out of the breathers...onto the valve covers?
Do you have a ton of blow-by happening? Worn rings?
With breathers on both valve covers there should be no crankcase pressure at all. But with alot of blow-by it'll spit out oil.
Old Sep 25, 2009 | 05:03 PM
FL Junkie's Avatar
there is no pcv on my engine. its not there. do i need to get the whole pcv system and connect it to a catch can?
Old Sep 25, 2009 | 05:04 PM
FL Junkie's Avatar
its not spitting out just coming out over time in vapors. like say after a few months you have some oil residue on the valve cover. its normal.
Old Sep 26, 2009 | 07:50 AM
TLewis4095's Avatar
It is easy enough to plumb a new PCV system on your motor that will be more effective than the OEM one.
If you want I'll walk you through it.
Old Sep 26, 2009 | 12:52 PM
405HP_Z06's Avatar
Here are diagrams for both the stock PCV system and the stock PCV system with a single catch can.
Stock:
Single catch can:
Old Sep 26, 2009 | 01:10 PM
99'CajunFirehawk157's Avatar
In that diagram, if I am not mistaken that passengers side is like a 1999, but 2000 (?) and up only have one line up front out of the valve cover but basically the layout is the same as far as plumbing to the catch can correct? What if you have the ls6 pcv mod, any difference?
Old Sep 26, 2009 | 02:31 PM
405HP_Z06's Avatar
If that's the case, ignore that port on the diagram. Here's with the LS6 valley
Old Sep 26, 2009 | 03:13 PM
Nice drawings Arron, work/school in Engineering?
Old Sep 26, 2009 | 03:34 PM
405HP_Z06's Avatar
Thanks. By trade I'm in IT.
Old Sep 26, 2009 | 11:57 PM
TURBO6.0L's Avatar
Nice work on the drawings. Would you be willing to make up a drawing for A PCV system for a forced induction setup? I already have a design for one that works really well but would really like a slick drawing like the one you made. The FI guys are all over the map with a bunch of crappy drawings and some weird ideas. I picture like that is worth 10,00 words. I would certainly give you credit for the help. PM me if interested and we can go from there. Thanks
Old Sep 27, 2009 | 08:41 AM
405HP_Z06's Avatar
PM sent
