Do stock pullies go bad?
or do you mean crank bearings? The motor is brand new...about 6000 miles on, so I highly doubt its crank bearings.
the vibrations are occuring at 1700 and 3500 rpm. sometimes its really bad, and sometimes its jsut enough to make my OCD kick in
There is no bearing for the crank pulley, it is pressed onto the crank and secured with a crank bolt. However the pulley is a two part pulley with a rubber like material between the two parts. If that **** rots out that outer part can develop a nasty wobble a cause vibration.
